The TPU uncovered? (A PROBABLE technique.)
Started by pauldude000, April 09, 2008, 08:35:14 PM
turbo
forest
I asked if somebody tested it, not if somebody knew it ....  Anyway thank you for answering so fast  :P
P.S. I know  that it's strongly related to TPU like SweetVTA, Ed Leedscalnin PMH and so on.
Sudonym
Quote from: Erfinder on August 07, 2008, 04:53:49 AM
Spin is EFFECT not CAUSE!  Where is spins origin?
why look so hard for the obvious? The origin is the center, without the center, the movement cannot exist.  :o
Grumpy
Quote from: Erfinder on August 09, 2008, 12:14:44 PM
It sounds like you are honestly looking for someone to spoon feed it to you!  How's that for honesty? LOL...
In addition, don't make the mistake in assuming that I don't have an answer.  If you were paying attention I said, I have an answer that I am satisfied with. Many won't like it, so, there is absolutely no point in discussing it.  I have indicated where one can go, by going there one can come to similar or in the best case the exact same conclusions that I have.  If and when that ever happens, then a real exchange can take place.  You are absolutely correct when you say that I am  quoting a genius, I quote them because they had the knowledge, they had the total comprehension, I am learning, they are the teachers, goto them, if you have a problem with my methods its yours not mine!
I don't have to learn how to apply anything, I am applying it!  LOL.... I don't care about the present condition of the world.  The world doesn't have my best interests at heart!  Don't expect me to explain anything!  I won't.  Don't expect me to show anything!  I don't have too.  Everything you need you already have, one individuals interpretation of another's works isn't what you need, you need to goto and interpret the source yourself.
Want me off the podium because I refuse to show the way, get over it!  If you are pissed because I keep bringing up the same tough question, then I suggest you ask yourself why you are pissed, and then ask yourself how much you really know about the topic, chances are your knowledge gap is the real reason why your pissed, again your problem not mine!
You are insane if you think I am going to let you run me off.....LOL, if you don't like my comments......I suggest you stop reading them!
This was a topic I started a long time ago but it never went anywhere.....nothings changed!  Homework time!  I know how much you hate that, but you have gotten so good at it!
Erfinder, have you become delusional?  Perhaps you just ate something that didn't agree with you and stomach upset is affecting your thinking.  If so, it will pass.
I have not asked you for anything - much less to be spoon-fed.
If you have an answer - share it - explain it - or be quiet about it.   If you are unable to share, explain, or use your answer then you have nothing that could be called "realistic".
No point in discussing it - yet you always bring it up - over and over again - your dying to discuss it.
"Real exchange"?  More discussion?  What about "action"?  That is where the rubber meets the road - "action".  Look at the work IronHead did with HHO - he experimented himself - he showed others how to do it - and patiently they passed the knowledge - now thousands are making HHO to supplment their autos - that is what "action" does.   "Action" teaches people how to think for themselves and that is what we need - to be able to think and act for ourselves - then we can seek the deeper understandings - until then we have no chance of understanding.
You don't care about the world and it's current state?  Perhaps you are so far advanced that you ar immune to everything around you - you are not.
I don't expect you to explain anything - you can't.
I want you off the podium because you only talk - you won't lead the way.
I'm not pissed at all.  I have my own understanding of what electricity is along with everything else.
I think you are selfish and you should not claim to know the answer to a question if you are not prepared to explain the answer.
        -Frank Edwards
sparks
  Innovation has a good point about the circuit not having to be resonant.  I believe resonance is the last thing we want.  Hysterisis is more like it.  We don't want the wave slapping back and forth and getting a little push each time.  It is grossly inefficient.  We want the kick ilicited mass reaction to end up doing work.   Altering the density of the energy field at the termination of a conductor field results in a shift in the energy density in the rest of the conductor. .  The oscillation of the density change causes waves of energy through the field of the copper mass.  Then it settles down as the stratified plazma field tunnels it's way through the conductor field.  Finally the copper mass becomes stratified enough to create a magnetic signature.  Why then does it take longer to get a magnetic signature when the wire is coiled compared to when it is a straight run?   The plazma field is effected by the geometry of the conducting field.  If the conductor in question is geometrically opposed to the leading edge of the tunneling field it begins to stretch out the stratified plane between the leading edge of the tunnel and the already stratifed conductor field.  The tunneling starts to effect less of the mass in the conductor field and more of the field in the plane of the turns of the conductor.  The leading edge of the plazma starts to dilute through the core of the solenoid.  At some point depending on the ability of the contained external field to stratify and the superconducted density intelligence coming from the scource,  the tunnel edge hits the end of the coil.  The core has saturated and the tunneling continues through the mass of the remaining conductor until it finally hits the end and jumps into the field.  The magnetic field is just the configuration of the plazma stratification of the space in question. As long as a change in density at the terminal end/ends is maintained the plazma field continues to grow and at least be maintained.   Now if we abruptly change the information at the terminal end.  The stratified layers can go back into the agitated state caused by ambient density field information.  No tunneling this time just collapse. Like the collapse of the pressure wave on the old jet fighters.  The density information/voltage of the entire coil field is now in play. It's collapse or discharge relavant only to fields of similar energy density.
   Bifilar wound pancake coils are very efficient in so much as dilution of the primary tunneling edge results in another tunneling edge in the similar mass field found within the influence of the outside coil.  When series wound they expotentially strengthen the coil energy storage capacity by containing the density information normally radiated about the coil into the field.  This information being exchanged between turns of the coil instead of radiating towards mass of similar energy density.  A load of high self inductance will now be able to be run in parallel with the standing dc field powered by the in out voltage of the plasmic capacitor field.
   Basically the coils can store the energy illicited from matching energy density fields when the energy density is changed in one.  Usually this occurs on a radio wave antennae and illicits an energy response in incomprehensible amounts of mass.  How many antennaes can "pickup" a 4watt cb radio transmission.  How many tons of steel get influenced by one little 4watt radio transmission.  Now concentrate that effect in a few ounces of copper or steel.  Is it any wonder the TPU starts to cook or mosfets are going poof. Energy of a given density seeks energy of similar density with little regard for what is in between.  Get a mass resonance match and pulse that shit.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
