The TPU uncovered? (A PROBABLE technique.)
Started by pauldude000, April 09, 2008, 08:35:14 PM
innovation_station
i just came up with a totaly wicket new tpu design it is so neat im gonna build it right now....
i dont think it will be posted tho  ;)
im gonna do a hand skeck  if people are intrested msg me i will send a copy of it to you i have not built this yet altho i would expect awsome results from an aa battery of course ...  im trying to increase current here....  and this may just do it
ist
4 jt on a copper primary kinda... lol
maybe i can call it a loop accelerator ... ;)
on second thought dont msg me ...  here is a pic insted   also i only used 3 jt's  just whiped it up took bout 5 min took longer to do the pics than to build ....
innovation_station
the unit showen in my above pic will be wired as followes...
pos feed from battery will travel through the bifiller collector wire first...just 1 strand  .... then it will power the driveing transistors ...  ok fine after that the out put from the 3 sepreate torroides will be dumped in the second wire of the bifillar collector  shot around the loops then used as out put ... this will be my frist crack at it  and i may just power the transistors from the battery insted  as the voltage may climb to a point where it could blow the transistors  :o
and i dont want to do that  but you see how the feed supply gets induced with extra power b4 it gets used ... then it gets used  and the returning engery is shot through the loops and is induced as well and is then used as output  kinda a dubble wammie  the hot gets added to then the cold gets added to ...
but i might just be out in left feild on this  i have not tryed it yet
ist
sparks
@Paul
      GK did this for an experiment a few months back.  I am not sure what impedance device he used for a load but the series lc should work with a transformer primary as the inductor.  This is a NO NO on a high mass torroidal.
We need alive researchers.
@Inno
    Hi Voltage Tranny  8)
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
sparks
     Another note is that there is very little iron in this flow diagram.  Iron responds to time unfolding or energy density intelligence by not conducting the information or passing it on but instead it reconfigures itself to match the information FLOW.  It doesn't have a defined magnetic field signature relative to energy density it creates one depending on how energy information is flowing through it.  It stores intelligence or creates the past.  This creates relativity between the past and the now.  (I am confident that our memorys are stored using iron on a cellular biological organization.  The computer guys are just getting around to developing magnetic memory.)    The energy density information of the Earth field is relavent to the energy density of the surrounding "space".  This creates a magnetic signature we call the magnetosphere.  In the same field there is formed iron crystalline structuring of the core in response to past energy flows.  This creates a natural oscillation between the energy flow creating the past and the past directing the energy flow.    Tesla's resonance?  SM's 5khz? Counter emf?  Schuman cavity wave resonance?  Could these be all effects of the same time oscillation in differing energy density fields?
Think Legacy
Spread the Love
innovation_station
well i finished the unit as posted above i have the 3 jt's working   now to run the output of them through the speeker wire ring ...
and see what the results are
i will post a pic in a few  also i made a awsome dwg this morn by hand for a 4 unit unit lol   with 4 feedback torroides in the design ..... as well as 4 jt's
pic soon
ist
