The TPU uncovered? (A PROBABLE technique.)
Started by pauldude000, April 09, 2008, 08:35:14 PM
forest
Look also at this simulation, picture nicely showing the inversion method for generating spin echo.
http://www.phys.tue.nl/MRL/TPM/porous/Restop10.html
forest
Look,I don't state that I understand this. Seriously for me most of this scientific notes are bla bla bla difficult ;-) In fact I'm very disappointed , because one nuclear scientist working with NMR would explain TPU and replicate in no time ! >:( Instead we must cope through tons of related quantum effects to find at the end that it is simple but to replicate need deep knowledge or many trials :-(
Another tip : magnetic positive feedback .
Imagine fast rotating metallic disk in stationary magnetic field. (homopolar generator). Now look at it from a point of view related to the surface of the disk.According to Special Theory of Relativity there is no difference in that point of view between rotating disk and rotating electric current inside non-rotating disk (except that this current must be steady not fluctuating, in other case that analogy is incorrect)
However weak external magnetic field is, the generated magnetic field is ADDED to it and now THERE IS ONE magnetic field .This is the source of pulse for iron core NMR. The spin echo intensity is then strictly related to that SUM  of internal and EXTERNAL magnetic fields. Internal magnetic field is not OU obviously , external magnetic field is weak also , but repeated SUM of those causes an echo, and the arrangement of coils must provide the path to collapse that echo in the way it extend the looping current.
You now see how difficult is this TPU to match all effect together. Basically it is HOMOPOLAR GENERATOR DRIVEN BY SPIN-ECHO of IRON LATTICE ORIENTATED IN EARTH MAGNETIC FIELD
Hmm..that explain large current output,right ? (look below)
"A homopolar generator, is a DC electrical generator that is made when a magnetic electrically conductive rotating disk has a different magnetic field passing through it (it can be thought of as slicing through the magnetic field). This creates a voltage and current difference between 2 contact points, one in the center of the disk the other on the outside of the disk. For simplicity one contact point can be considered positive +, and the other contact point can be considered ground or negative(- or 0). In general the 2 contact points are linked together as the armature. It has the same polarity at every point, so that the armature that passes through the magnetic field lines of force continually move in the same direction.[1] The device is electrically symmetrical[1] (bidirectional), and generates continuous direct current. It is also known as a unipolar generator, acyclic generator, disk dynamo, or Faraday disk. Relatively speaking they generate tremendous electric current (10 to 10000 amperes) but at low potential differences (typically 0.5 to 3 volts), this is one of the major disadvantages of this type of electric motor."
http://en.wikipedia.org/wiki/Homopolar_generator
Michelinho
Re forest.
QuoteLook,I don't state that I understand this.
Do you think I do? This thing for me is logical, but it doesn't mean I understand all the underlying. I have a college degree in general business administration and was a mechanic most of my working life.
I have acquired most of my knowledge on new energy since last year and started studying the Stubblefield cell more or less seriously 2 months ago. I have set my goals on that project and used all the means at my disposal to successfully reproduce a Stubblefield Cell and I know I can do it.
As soon as I have all the stuff needed I'll start the project. Still missing the soft black annealed iron wire I intend to use in my initial test.
Take care,
Michel
MACEDONIA CD
@ michelin
man where is   static fild of tpu then ifis that some  athere
   way then the small tpu  dont work up said down?
innovation_station
ok guys
i was playing with my bedini motor last night ....  need i say more....
i guess i better  ;D
to set up a self triggering kicker.... ;)
ok when the magnet is located  in the right place look at the kicks with out any movement  ;D
could this be how the tpu operates??
"im gonna turn on this device with the use of a single magnet...."  SM's words....
i used an air core coil for my motor ...   and a neo and a reed with a cap across it    jets just say it sings ......  WITH OUT ANY MOVEMENT... OF MY MOTOR  :o
ist
