Stubblefield coils (bifilar) and speculations
Started by Pirate88179, April 09, 2008, 09:43:54 PM
xee2
@ Pirate88179
I am still puzzled at how you can charge a 640 Farad capacitor so quickly. I think the attached calculations are correct. Theoretically you would need an average of about 100 ma to charge it to 1 volt in 4 to 9 hours. Charging to 2 volts would take 4 times as long and require 2 volts from EB. Would you be willing to measure the current going into the battery while it is being charged to see if it is about 100 ma? I may need to study my theory some more.
Pirate88179
XEE2:
I don't think those figures are correct at all.  At least not for supercaps which are totally different.  About 2 years ago, Coleman came out with a cordless screwdriver that had no batteries only supercaps.  The standard lithium battery took 8 hours to fully charge and would run the drill for 4 hours.  The supercap version would only run the drill for 2 hours, BUT, would fully recharge in 5 minutes!  The technology has improved since that time and you are going to see more of these replacing rechargeable batteries in many applications.
Also, about 2 years ago, my first supercap (.47 F 5.5 volt) would charge up from the old style EB in like 5 seconds of connection and would run a red led for over 15 minutes.
Nabo00o
Quote from: Pirate88179 on June 10, 2009, 02:18:31 PM
Say what!!!??? That sounds like more power than you have been using in your loads, even the florescent bulb and motor....   Its just incredible. And you know what I think? Its radiant energy!
That neon bulb I used with the earth wire, it lit up just the same way as when I move it close to any of the wires on the solid state SSG, and I'm pretty sure it is a radient event which allows that energy to be transmitted wirelessly. Just like the spikes with almost pure potential can recharge a battery extremely efficient, maybe an earth battery does almost the same with a supercap. At least its something to think about  :-\
Nab
Static energy...
Dynamic energy...
Two forms of the same.
xee2
@ Nabo00o
Quote from: Nabo00o on June 10, 2009, 03:47:43 PM
Neon lit with one lead by high voltage JT. Power lead from JT can be grounded to earth.
Nabo00o
Quote from: xee2 on June 10, 2009, 04:27:33 PM
@ Nabo00o
Well I know that, I see it in your image. However I can make it light by simply placing it near the wire of my SSG even without touching it, a spark gap does also seem to magnify the effect.
If I touch the bulb on the glass it glows very brightly and if I touch a lead or connect it to the ground or a plate it will light extremely bright. Anyway, it seem hard even to explain how one wire can carry any real power, which is I * V. But when it is pure voltage coming of as a field, and it still makes stuff light up, I wonder how we use up power to make that happen...
This much like the Avramenko setup, just without the diodes and capacitor.
Naboo
Static energy...
Dynamic energy...
