Roll on the 20th June
0 Members and 150 Guests are viewing this topic.
CLaNZeR
Interesting! and thanks for the interaction Archer, most people that claim this sort of break through seem to disappear and never see it through to the end.
I am better with pictures to understand stuff and find reading your explanantions hard going, but reading your clues over and over I do understand where you are coming from.
Will hold back dragging out the welding machine till a little bit closer to the date this end.
But defo up for a go of making this one if you are still going strong with it.
Good stuff and Roll On June!
Cheers
Sean.
http://www.overunity.org.uk
CLaNZeR
So add weight at 1 O'Clock and remove it at 7 O'Clock without using more energy than what was created by the 180 degree revolution?.
helmut
Quote from: The Eskimo Quinn on May 01, 2008, 07:38:09 AM
tried, attached as photo as large as the sire would allow
@Archer
I did my guess about the driveheads (Pic)
:First i do not expect to get the right answer.
But just for the Fun:
Somewhere in your discription was a reference about the spokes.
As i remember you stated ,that the Pipe is all ready filled with air.
So i think:
The Driveheads work as a valve.To get the Wheel moving fast,it does need a instand Air movement (Exchange) inside
the Spoke(pipe).The valve is open ,if the distance from Disc to Disk is like in the Photograph.
During the operation to propel the weight up,the disc are together without a gap and make shure that the Piston
will be driven fast.
Thats my guess
helmut
p.s.: The actuator might work via vacuum
and the Magnets are used to do the timing
Can you explain or give a hint what about the mysterious Driveheads
Thanks helmut
CLaNZeR
Are these simply sliding weights?
Cheers
Sean.
helmut
Quote from: CLaNZeR on May 02, 2008, 01:31:48 PM
Cheers
Sean.
@CLaNZeR  @Archer
The Quality of your Pics is very good so one can see better details.
What we have learnd the last days is,that a heavy Wheel can be brought in motion
with just a fracture of the Wheel Weight.
So it might be possible,that the Stack of big Discs can be shiftet together ore streched,so they
are on the Pic with gaps between eachother.This funktion might result the overbalanced situation.
helmut
