Roll on the 20th June
Rusty_Springs
Hi All
I don't think I have explaned this so I will do it now.
I can make magnetic gates because I use angles and distance to get the flux going the way I want, if you angle a magnet you get the flux you want to use closer to the roller magnet and the flux going the other way that you don't want to use further from the roller.
Then if you add another magnet angled the other way the flux you don't want goes into the other magnet and the flux you want is out looking for the roller, I added the steelball not to shield the flux but to smooth it out so the roller will pass smoothly, it will work with out the steelball but you get a stop start motion instead of a smooth roll.
Take Care All
Graham
LittleHelper
Graham, have you ever thought of making the Tri-gate like a double wheel? And have the "running" magnet sit locked just outside the "wheel"? I guess if you make the wheel big enough the magnetic fields won't disturbe each other on opposite sides too much.
Cracked it!!! I think... ;)
fletcher
Or, have the tri-gate attached to the wheel - let it go from 12.01 o'cl so it pendulums - have a steel ball permanently mounted [not part of the revolving wheel] at 6 o'cl [for example] just below the rim, but the tri-gate can pass around it - then if there is more thrust in one direction [the direction of travel] the wheel & tri-gate should swing higher than the same setup & release without the steel ball as a datum control measurement ?!?
capthook
Can you place numerous trigates spaced around a horizontal wheel with the "roller" magnets actually fixed to the wheel to provide continous motion of the wheel?
Why/why not?
The Eskimo Quinn
Not here to have conversations, just thought i would save a lot of what ifs. a "tri gate" wheel already exists, the concept is not knew, though his use of the magnets to find an old mag train was different. go to youtube and look for magnetic trains there are heaps of them, there are spinning cylinders too.
they work best at horizotal becuase of the unseen flaw for use. the only power they have is standard float, the same as the rods. the power of them is limited to what weight the can support vertically in suspension, as that shows the power of thrust or drive. Additionally spheres have less of a wall than cylinders and cubes, so they work best, yet you cannot make large ones due to the location of the poles. "inside and out" so you can never get the power.
However if you want you can use them as tappers for machines that suffer friction problems, and no you cant spin a wheel to high speed and tap it along, that comes back to 1 tone on either side of a balance beam over weighted by one ounce, you simply have one ounce of power.
The orginal flying ball bearing machine works this way.
On its own it has not a lot of value, as part of a dual system it would be perfect. Albeit i am sure with 5000 dollars worth of the small spheres you could charge a small battery every day. Just dont go vertical they have even less lift, or use it to accelerate a vertical already running that has weight and power.
I thought I should say something because this is a discovery that has been overlooked for a very long time, and I think his use of it in the videos is a good example of it. Dont care what you think of me, a least give this guy a shot, check the mag trains etc and you will see he really does have a good idea for use that is proven not theory.
My PROOF THAT DEMOCRACY IS DEAD AND THAT WE MUST ATTACK AND KILL THE NAZIS IS RIGHT IN FRONT OF YOU, THE U.S, aUSTRALIAN AND BRITSIH GOVERNMENTS ARE THE OPPOSITION PARTIES TO THE ORIGINAL INVADING GOVERNMENTS, DEMOCRACY DIDN'T WORK, BOTH MAINSTREAM PARTIES ARE NAZIS, DEATH TO THE NAZIS, DEATH TO ALL SYMPATHIZERS AND SUPPORTERS http://www.youtube.com/watch?v=39c-kpgDY58&feature=related
