Roll on the 20th June
0 Members and 27 Guests are viewing this topic.
helmut
Quote from: exxcomm0n on July 15, 2008, 12:08:30 AM
Finally.
Had to go to the womans house cause she was housing the nice video equipment.
Here it is:
http://www.youtube.com/v/ItsbTlj04b8
Mayernik Effect in an arc without mechanical influence.
@ExxcommOn
Good work
Perhaps one time you like to remove the Magnets on the right side from 1 oclock to 6 oclock.
and crank the board just a little .
And than led fall the rotor from 1 oclock into the track.
helmut
gwhy!
Hi Guys,
ONEWAY MAGNETIC GATE....!!!!!!
Thought I would put this up. Needs to have a lot more testing and tweeking but at least in its basic form as shown it  removes a hell of a lot of the sticky spot at the end of the input array..... The picture shows arrangment but is not to scale.
LarryC
@All,
Thinking about what Archer said about keeping it low cost and him running out of magnets. I've been holding off buying more mags for a full test until the dust settles. Remembered that some mag expect on another thread said something about when you stack neos that at first it is proportional in strength, but then it starts dropping off. Also, since the majority of the flux is coming out of each end, why have them all the way across. All that is needed is a flux path in the middle.
The mag array on the left has laminated steel in the middle (50%) and magnets on each end (25% each). The mag array on the right has all magnets. The roller is in the middle. Both mag arrays starting pulling the roller at 100 MM and the roller went pass the same distance in both cases ;D
@gwhy,
Thinks for the drawing, I was having trouble picturing your overlap. Our original goal was to break the wall at the top of the 45, hoping you can tweak enough to get there.
Regards, Larry
futuristic
@gwhy!:
Looking great! I can't wait to try it out.  ;)
sm0ky2
Quote from: purepower on July 09, 2008, 08:06:18 PM
Okay, I think I know where you re going with this...
First off, this is a tangent from my original statement. Archer said to lift the roller a height x will take less energy on a wheel than going strait up. This is not true, as per my support and evidence.
apparently you missed the video of a single Man lifting a CAR and moving it around,
simply by putting it on a giant WHEEL.....
While i will agree that the potential energy of a car @ height x is the same in both cases, the energy required to get it there can vary drastically on a wheel vs a straight lift.
1 a man can do by himself, the second couldn't be done by 2 or 3 men.
