Roll on the 20th June
sm0ky2
Quote from: purepower on July 13, 2008, 12:29:30 AM
Um, correction:
I still stand by all of this if the mechanics truly manipulate the field to turn it on and off.
If it is a mechanical system that pulls the magnet away from the material with a screw-like action, then there is nothing special.
I'm gonna have to do a bit of research on these things...
-PurePower
you're on the right track here. What they are using is the principle of magnetic induction at distance X.
the "active surface" of the magnet is a ferrous material, such as steel alloy.
the magnet is moved towards and away from that steel by a screw-like action. (very steep threads!!!)
when the magnet is closer to the steel than distance X, the steel is magnetized,
when it is further than distance X, it is too far away to cause induction, the field is sheilded at the inside surface of the steel.
the "non-active" surfaces of the device are shielded in a similar manner, at greater than distance X
so that the magnetic field is completely blocked inside the device.
The real question is: does the screw-like mechanism give some sort of advantage vs. the strength of the field when it is turned "on" ??
My guess would be no, but without seeing the particular incline of the threads, and leverage of the handle mechanism, i couldn't prove that..   These 2 factors seem to vary with the field strength among their various contraptions that they sell.
some have big hunking bar-handles you have to turn to shut it off/back on again
but they also lift hundreds of kilos so... one has to wonder...
Their work on oceanic recovery systems is amazing,  can litterally drop a cable-rig, turn it on when they need to, and bring the stuff up. turn it off to drop it onto a barge or whatnot.
Fred Flintstone
I went back and viewed Batman's videos again. From the videos he has no wall going in and no wall going out. It least that is what it looks like to me. We need to figured out what arrangement he has on his magnets.
Freddy
Rusty_Springs
Hi All
The fact is everyday I say to myself I don't want to make any comments on here today and then Archer or has lackies pull me in with crap like the bio thingy, if you just except the facts, I would be just checking in to see if anything is happening and not commenting but you have to keep dragging me in.
What your saying about my onepulse motor is proving I'm not a liar why because I said the video has been there for ages, you just have to click it and watch it spin, someone ask if I still have a prototype I could have said yeah but I didn't I told the truth and said no and why I didn't. so weres the lie there, also I never said it was OU or FE and I also said it ran only with the help of an electromagnet, no lie there ever.
Lets look at the facts of what Archers knows about magnetic, first he said a donut magnet doesn't have poles on ever side, I had a good laugh over that, then he said you can't put two block magnets together side by side, that was a hoot.
The fact is both systems are the same principle just using different type of magnets but mine was done first, if there the same principle then I have no need to show it going up and over a hill because it will act no different to Archers and he has shown that, what I have show is it breaking the wall on a level surface not using gravity and in Archers words that can't be done, I'm sure he said you can only break the wall using gravity yet I have shown 3 gates that do it with out using gravity.
If you don't want me responding to your false claims Archer then stop bringing me in by trying to attract the truth, just show everyone your working wheel, oh and I have never made a false claim that I have or had a working OU or FE wheel like you have, if what you say about your wheel is the truth and honest then show it or rebiuld it and show it but you can't because you never had one in the first place and going on the path you are you never will have one.
Hopefully this is the last I have to say on this if not its because Archer or his lackies have brought me in again.
Take Care All
Graham
The Eskimo Quinn
Did a bit of reseach, turns out isotropic ferrite is what most ferro block mags are made of, so i used some old block to test theory of the spring switch.
do this at home get a ferro block magnet, flat ferro mags dont seem to work too well, may be different stuff.
anyway find an item it cant quite pick up, get a drill bit and touch it on a large neo and the block and you will find it will pick it up, now break the connection with the drill bit at the ferro block and it drops,
so it works just fine
use as a switch As described with an ally plate and springs to pull the roller onto a set of ferros say around three sets to get it past the pull of the neos above, once it rolls off the aluminium plate with the springs the connection will break and the roller will fall.
As my words seems to be worth shit no matter what i show you, i have given you this example to try for yourself at home.
So for those not going for the speed release, this may solve your problem.
gotta go.
oh and after 12 hours i would have thought at least one other human on the planet would have realised that the switch will apply to every train shunt ever made.
That invention alone may end up bigger than everything, as it changes everything, no more walls
My PROOF THAT DEMOCRACY IS DEAD AND THAT WE MUST ATTACK AND KILL THE NAZIS IS RIGHT IN FRONT OF YOU, THE U.S, aUSTRALIAN AND BRITSIH GOVERNMENTS ARE THE OPPOSITION PARTIES TO THE ORIGINAL INVADING GOVERNMENTS, DEMOCRACY DIDN'T WORK, BOTH MAINSTREAM PARTIES ARE NAZIS, DEATH TO THE NAZIS, DEATH TO ALL SYMPATHIZERS AND SUPPORTERS http://www.youtube.com/watch?v=39c-kpgDY58&feature=related
gwhy!
Quote from: ezzob on July 17, 2008, 04:53:35 PM
GWHY!
What is the name of the oil company your are working ?????? ::) ::) ::)
SHELL    ;D   grow up
