Roll on the 20th June
X00013
This is an older vid, but about have way thru it, i got a wicked flashback of what Archer is tryin 2 do and what he is going thru.  http://www.youtube.com/watch?v=vSC2tATcAck&feature=related
madsen
Quote from: The Eskimo Quinn on August 03, 2008, 07:52:14 PM
@ Madsen
Yes, but kilowatt-hours is not the same thing as kilowatts.  As I said before, a kilowatt is a unit of power, not of energy.
well that'll be your little secret
http://www.google.com.au/search?hl=en&pwst=1&defl=en&q=define:Kilowatt+Hour&sa=X&oi=glossary_definition&ct=title
or from   http://www.energysmart.com.au/sedatoolbox/esm1.asp
A kilowatt hour (kWh) is the unit of energy that is used to measure electricity
I spent almost 2 years as a production manager for an electrical engineering firm building heating equipment where the calculations for kilowatts to heat energy was a daily task, i also spent a month this year building gas heating equipment which also like magnets is a different form of energy, that too was also measured in kilowatts or kilowatt hours, in fact all such equipment now usually has a sticker telling you how many kilowatt hours (kilowatts) it uses, and it does not use electricity. Kilowatt hours is how many kilowatts it uses in an hour regardless of the type of energy used nothing more and nothing less.
You are out of your depth here
Energy is measured in kilowatt-hours.  Power is measured in kilowatts.  You are using the two terms as if they were synonymous.  Your original statement, which I objected to, was:
Quote from: The Eskimo Quinnall types of lift are broken down eventually into kilowatts of energy used
Good Lord.
The Eskimo Quinn
lift,released kinetic energy, a falling weight, the push power or repulsion power of an object is all measured in footpounds which again can be measured in newton metres and again measeured in kilowatt hours or how many kilowatts an hour this fall or push produces or how many kilowatts per hour or kilowatt hours is needed to produce the same result.
I stand by the remark as exceptionally accurate
have to go will ba back later on today hopefully, as i wish to copy some of the posts of mine today and repeat on the next page to avoid those same questions again being thrown around the thread.
My PROOF THAT DEMOCRACY IS DEAD AND THAT WE MUST ATTACK AND KILL THE NAZIS IS RIGHT IN FRONT OF YOU, THE U.S, aUSTRALIAN AND BRITSIH GOVERNMENTS ARE THE OPPOSITION PARTIES TO THE ORIGINAL INVADING GOVERNMENTS, DEMOCRACY DIDN'T WORK, BOTH MAINSTREAM PARTIES ARE NAZIS, DEATH TO THE NAZIS, DEATH TO ALL SYMPATHIZERS AND SUPPORTERS http://www.youtube.com/watch?v=39c-kpgDY58&feature=related
X00013
When the vid hits 4:50 is when i had that flashback to here and now.
