Roll on the 20th June
0 Members and 108 Guests are viewing this topic.
Slavo
fuckin bullkshit disinformation
this "primary goal is disinformation" bullshit is you will never try anything
thing with magnets and rod is so fuckin obvious it must work if you think about how weight travels and not the tube, the weight travels in sort of a half circle
imagine for simplicity you will have symmetric straignt line type field - as if magnetic field will have same configuration as electric field from plus to minus -
means plus is at 7 o'clock minus at 1'oclock and the force on the weight acts in such a way that it pushes weight from plus to minus
this case means you have no wall
so what happens with the weight?
when is it at 7 o'clock it travels to 1 o'clock then it travels in half a circle to due to gravity and gaining momentum (in this case maximum momentum is gained when plus is at 31 minutes and minus at 1 minute) 7 o'clock then fires to 1'oclock and again and again
now the real field is on sides not straight line type so you have in reality this wall which is overcomed by adding weights to end of rod as on archers pic
infringer
-L
Ok rather interesting mochine :P
salvo
Welcome to the forum do you have a video showing how your concept is better?
A youtube account is free and I used to download 700mb linux iso's on my 56k so speed shouldnt be an issue either...
anyhow how you comming excomm? I'm thinking I may go for the CD or HDD motor for initial testing possibly floppy disk even...
Take care folks keep up the good info!
REGISTER AND BECOME A MEMBER RIGHT NOW!!!!!
........::::::::: http://www.energyinfringer.com  :::::::::........
"""""""everything is energy and energy is everything""""""
-infringer-
spider4re
I would rather have a PMG than government controlled electricity!!!
Scientist Creates Cold Fusion For the First Time In Decades
http://gizmodo.com/393119/scientist-creates-cold-fusion-for-the-first-time-in-decades
exxcomm0n
Quote from: infringer on May 24, 2008, 02:27:55 PM
I'm.......being lazy (One of the things I excel at).
Actually here in the states it's Memorial Day weekend, so my time is going to be sliced and diced by many social occasions and I might not get much done.
I have gone for the 2 tube - one magnet rod design mentioned by redriderno22 and worked on it until early morning.
It's soooooooo close. I can see it!
The second tube is mounted directly over the magrod tube with a much longer rod that has a penny rubber banded to each end for weight. The mag rod and the weight rod are joined in the center by a piece of plastic zip strip fastener that I carved up traveling between slots cut in each of the tubes.
Sounds strange, and probably not the right design, but I couldn't think of another way to get the weight farther out than the magnet and still have the magnet push the wieght any other way at the time.
I hope to have a video of the toy running, while I diddle on my guitar to fill time (most machines like this are bashed for the video not lasting longer. I'll run it the full 10 min. AND make the viewer wish that I'd cut it short ;) ).
I look forward to seeing your machine too!
When I stop learning, plant me.
I'm already of less use than a tree.
b0rg13
Quote from: exxcomm0n on May 24, 2008, 06:41:40 PM
oh come on! make the vid 30secs long and in a dark room!. ;D
if you want to get out of the rat race,you have to let go of the cheese.
