Roll on the 20th June
0 Members and 142 Guests are viewing this topic.
LittleHelper
Hi all.
Let me start by saying i've been following this thread (and forum) only for the last week or so, and I'm impressed with the creativity of people.
I have an idea which could repair redriners wheel (maybe)
Cut holes (3+) and insert supportwheels from the back. If you get it balanced right it should be moving once again, and help prevent it going wagling.
See sketch below.
Great Dane
Cracked it!!! I think... ;)
redriderno22
accually im going to completely rebuild it
and get rid of the hard drive motor
and stop using hot glue :o
Archer, how can i get the rpm's up?
more tube/rods?
just wondering
thanks again
redriderno22
CLaNZeR
Quote from: redriderno22 on May 26, 2008, 08:07:04 AM
and for those who havent seen the vid yet
http://www.youtube.com/watch?v=m1BK5mp8180
Nice going Redriderno22
Look forward to seeing it go when repaired.
I like the idea of adding Pennies to get the weight correct.
Cheers
Sean.
http://www.overunity.org.uk
CLaNZeR
Quick update from me.
I was going to use Mecanno strips to join each slider, but then had a thought about using Hacksaw blades instead.
These are thin, strong and lightweight. Bit of a devil to cut and drill, but work a treat.
Have done a quick video also to show how smooth these sliders are. There is no weight on the ends at the moment and they still slide, with the odd one sticking every now and then :).
I think it is a good idea to reduce the friction in as many areas as you can while building it up, because trying to do this later will be just stepping back as such.
I will add brass poles next to each polycarbonate slider mount which will the added weight and fix some magnets on the end.
Here is the video of the progress so far.
http://www.overunity.org.uk/aq/CLaNZeRandTheSwordofGod1.wmv
Cheers
Sean.
