Thanks to ALL for your help!!
Tesla coil electrostatic
Started by argona369, May 03, 2008, 01:11:45 AM
argona369
More on the electron shuttle (missing the tertiary ?magnetic capacitor?? (inverse to inductor) coil)
In regards to the ?piston?,
?He found that this pumping could be done with a piston "not connected to anything else, but was perfectly free to vibrate at an enormous rate?
?During a portion of its cycle the coil will appear to the earth's electric field as one plate of a capacitor?
http://home.comcast.net/~onichelson/Fuelless.pdf
http://tesla.nichelson.googlepages.com/home
the ?sink?,
http://home.comcast.net/~onichelson/Thermodynamics2.pdf
?People walking along the streets were amazed to see sparks jumping
between their feet and the ground, and flames of electricity would spring from a tap when anyone turned them on for a drink of water.?
"lightning arresters in the power house showed a stream of blue-white sparks passing
between the metal plates to the earth connection"
?<Then you are not making use of Hertz waves?? <Certainly not??
http://home.comcast.net/~onichelson/ONichelsonTUNGUSKA.pdf
the spark gap (might) be the ?motive force? as in,
"I have harnessed the cosmic
rays and caused them to operate a motive device."
?the current driving the turbine.?
http://www.pbs.org/tesla/res/res_art07.html
http://www.pbs.org/tesla/res/res_arts.html
interestiing "classic driven" version,
and the much more advanced and sleeker ?UFO engine? design to the right of it.
A truly sleek work of art.
(btw, the bifilar coil might be only electrostaticly connected,
two wires wound together but not connected together)
http://peswiki.com/index.php/PowerPedia:Magnifying_Transmitter
and, Tesla's magnifying transmitter/receiver looks a bit like a left hand transmission line,
http://www.edt.bham.ac.uk/hightemp.htm
It really does look like a left hand line here?
Secondary is source, spark gap is capacitor, "extra coil" is
inductance to ground.
http://www.bibliotecapleyades.net/tesla/coloradonotes/images/colora282.gif
interesting.
Cliff,
argona369
is fig 3 possibly the "sink"?
"it might introduce many errors, principally on account of its complex action upon the coil, as a condenser of very small capacity and as an electrostatic and electromagnetic screen"
http://www.tfcbooks.com/tesla/1892-02-03.htm#TRANSFORMER
added:
non-hertzian transmitter.
A 100 year old left hand meta material transmission line transmitter?
The Transmission Of Electric Energy Without Wires
Electrical World and Engineer, March 5, 1904
?This is, essentially, a circuit of very high self-induction and small resistance which in its arrangement, mode of excitation and action, may be said to be the diametrical opposite of a transmitting circuit typical of telegraphy by Hertzian or electromagnetic radiations?
http://www.pbs.org/tesla/res/res_art08.html
argona369
Just some thoughts on the Linde liquid air cycle.
http://www.linde.com/international/web/linde/like35lindecom.nsf/docbyalias/page_ch_chronicle_18911934details_1
and Tesla?s comments that, that was all he needed to prove his concept.
the heat exchanger runs in opposite directions, high pressure in one.
Low pressure in the other, recycle closed system.
The Tesla magnifying transmitter coil (flat panckae tesla coil) I would bet,
Is a bifilar secondary (currents running in opposite directions),
And might even be disconnected from each other, though
Electrostatic connected together. (a capacitor as well as a transformer)
How this fits into the sink is still unknown to me at this point.
Added:
It might also be two (separate) bifilar pancake tesla coils.
Just one with disconnected bifilar might not induce current.
argona369
there?s a very interesting ?infinite wavelength? meta LH/RH TM line
device here.
A pure standing voltage.
http://www.pat2pdf.org/
Enter 20080001684 in the patent field.
argona369
Well that?s weird,
Re:
http://www.bibliotecapleyades.net/tesla/coloradonotes/coloradonotes02.htm#Colorado%20Springs%20Notes%20-%20June%201-30,%201899
First his  (very weird) zinc (can) battery. (look at the strange series connections too)
In ?EXPERIMENTS WITH ALTERNATE CURRENTS OF HIGH POTENTIAL AND HIGH FREQUENCY?
He says about his transformer and zinc, ?it might introduce many errors, principally on account of its complex action upon the coil, as a condenser of very small capacity and as an electrostatic and electromagnetic screen?
Then in the next drawing and below,
Notice the very strange plasma tube he was working on. (linear homopolar?)
And then, the tube in the middle bottom of one of his receivers,
http://www.bibliotecapleyades.net/tesla/coloradonotes/images/colora274.gif
strange.
Cliff,
Added:
*Diamagnetic* (zinc) can, also a diamagnetic type of carbon? .
A regular D cell battery (not alkaline)
Is a zinc can with a carbon rod inside.
Might be too small to experiment with though, Tesla mentions a quarter
square foot for his battery (array?)
interesting,,,
