I'm not one to get prematurely excited...but can someone explain this
Started by Cap-Z-ro, May 08, 2008, 06:34:41 PM
Cap-Z-ro
You are right IHead...something is happening that needs exploring.
Can this 'movement' be amplified..or applied to start something else ?
Regards...
forest
I think that alkaline batteries can be charged but normally they heat up and explode .Today I left them and forgot and one was boiling when I finally checked !
However Bedini showed that such batteries (exactly 9V alkaline) can be charged with his method and it remain cold. John Bedini post such comment someday : "Granted that a non-rechargeable battery is not a proper candidate for testing this technology, but if such can be recharged at all, which I do all the time, then that is savings for us all."
Looking at his circuit I think that even a coil with diode and battery could work in place when magnetic field is disturbed (there are such anomalies of Earth magnetic field)
IronHead
No matter of coil size or magnetic field strength  I still see nothing but Ghost charge.
It also must be mentioned that I do not live near any high power electric line or radio
type broadcasting.  I will still fool around with this to see what can be done. I would like
to hear what you guys that are using running motor have found.
Carbon brush breakdown charging and such..
Cap-Z-ro
I'm still trying various combinations of things along the same lines...along with considering some other concepts.
Nothing to report as yet though.
My original motor charger has slowly climbed to 8.02 vdc.
I am shortly going to run the test inside a dormant microwave oven - to establish whether or not an unknown source responsible for the charging effect.
Regards...
gn0stik
Could it just be that this setup forces the ambient charge in the caps into the battery? Since there's no real current in the ambient charge of a cap, there's no real power being imparted. The reason it's all cold is because there's no current. It's all voltage.
Tell me this, can you run a very tiny load, say an LED, while still charging the bat in this fashion?
This should be impossible with normal energy. However your single wire charging make me think perhaps we're not just dealing with normal energy. Ed gray split the positive at very very high voltages, inside a cage to capture it. If this is similar in any way, it's an inversion of some type.
I tell you this, neither configuration should do anything at all. Interesting.
