FREE ENERGY USING MAGNETS
Started by nightlife, May 13, 2008, 11:27:44 AM
petersone
Hi Gyula
I would be very grateful if you could comment on the enclosed sketch,I built one today and it seems to work,I think I need to use a coil with thinner wire as I am only just turning the diode on,is generating usually done with high volts?
If you think it's a non-runner just say so!!!
happy hunting
peter
gyulasun
Quote from: petersone on May 31, 2008, 06:24:45 PM
Hi Gyula
happy hunting
peter
Hi Peter,
If I understand your drawing, basically you wish to make a generator driven by a motor, right?
Well, to answer you question a diode like 1N4007 or 1N4148 and the like needs higher than 0.7V peak voltage to be able to conduct current, below that it behaves as an open circuit,  and of course its anode should be 0.7V more positive with respect to its cathode to conduct.  In the drawing the diode should be reversed to get the positive half waves you indicated there with respect to the other wire end.
Yes, if you make a coil with thinner wire, you will have more room for more turns if you mean that and more turns will induce higher output voltage for sure.
You have at least two coils at the moment built-in, facing both the iron pieces and the magnets?
I also ask you really have not got any iron core in the coil?  This also explains the lower induced voltage, increase of the number of turns helps on this. The pitfall may be with the thinner wire and more turns is that the inner resistance of the generator  coil increases hence the copper loss also increases when you try loading the output.
If you would explain in a bit more detail the text in the lower right column, It is not a 100% clear for me ?  I figure you hope in a no Lenz generator but I am afraid as long as your output is low the output current for your whatever load is also low hence the Lenz effect is also low... :(     At the moment this all I can comment on this.
rgds,  Gyula
petersone
Hi Gyula
Thanks for your fast return!!
I understand small watts out,small lenz effect,but what I found strange was the diode one way,I can "see" the lenz effect,but the other way no lenz effect.because,I hope,when it's the "wrong"way,it is generating on leaving the coil,and that's no good,but the right way I can't "see"any lenz.
what I said on the sketch was,
when the magnet approaches the coil,normal lenz effect on the magnet end,but the iron is being pulled to the coil at the other end so cancels lenz out,a diode to switch off the coil when the magnet and iron leave the coil.
petersone
Hi Gyula,again
Forgot to say,just the one coil at the moment,but could add more,with no core,just air!!
happy hunting
peter
petersone
Hi Gyula,again,again.
Forgot to ask,do you know of  any diodes that switch at a lower voltage?
happy hunting.
peter
