Is Lindsay?s ?SM? a fraud?
Started by RobotHead, May 19, 2008, 11:55:42 PM
0 Members and 18 Guests are viewing this topic.
Grumpy
Quote from: buzz-ard on July 15, 2008, 12:11:10 PM
(No insult intended, Grumpy)
"Orgone", the way I recall, is "orgasmic energy". If someone can come up with way to collect that, or even measure it, they'll really have something!
I used to term "orgone" to indicate that the scalar, tempic, longitudinal stuff is the same as Reich's orgone, or primal energy.
        -Frank Edwards
starcruiser
After a bit more research I think the TPU is nothing more than a modified DC generator of sorts, The coils were orientated 90 degrees from the traditional direction. The armature could be the center torrid coil and the collectors (outside rings/wire) are the field (control) windings. This is a theory at the moment but the OTPU, the second version shows a clearer picture of it and seems to back this up. Take a look at the attached for a simple schematic of a DC generator. Here is the URL for the page I took this from, there is additional info that may be of interest. http://www.tpub.com/content/doe/h1011v2/css/h1011v2_94.htm
The only thing really required is a rotating field which I believe can be created using the specially wound center torrid assembly to emulate a turning armature. The external magnet would be used for exciting the coils to start the process.
A few turns of bailing wire would be required for the magnetic core. The actual circuit is basically a hybrid DC/induction generator. A capacitor would be required for output smoothing and one or two for the oscillator (LC tank) which drives the center torrid/armature. This would create a DC component with some hash due to the peaking of the half wave output of the generator.
As for the center torrid, this could be made from a simple wire spool with a few turns of bailing wire which is wrapped over with a few coils, one standard coil for the LC tank and one for the drive/tickler (these could be one coil). the outer coil is the split wound design (CW/CCW) to force the pulse train in one direction, this outer coil is what drives the field windings/controls.
Just some food for thought guys.
Regards,
Carl
innovation_station
kinda like a brushless dc motor with a collector wraped round it  :D
or a self vibrating relay telling the power where to go ...   in other words give it only 1 path  it will naturally look fo thr path of least resistance..
so make your load is the path and be sure your load has less restance than the rest of the unit... the output cap does serve a big propous more than just smothing out the ripples
it is your convertor ...   now this is confusing and it seams i conterdict myself this is just not the case.....
there many diffrent tpus and such they all work diffrently ...
1 thing for sure the free CAKE COMES FROM THE KICK
IST
altium
Otto, I try to draw your shem with two different colors for control coils. Are this drawing is correct?
innovation_station
anyone ever do a pancake on a pancake 90 deg ?? then add a peice of steel wire to each one ???
dont make me draw a pic agin....
keep it simple  :)
ist
in what i just wrote   visualize it ...    see it in your mind ...   build it in your mind ...   then assess  its operation in your mind ... then take to paper ...   trace the path of the electron in your mind   what will happen as the electricty enters the steel ?      and when you cut the power from the source what will happen ....?    how does the sterling engine work??   WATER HAMMER ;D
how does this work what does it do when you apply power to it   keep it real simple
just like ottos lil test   50 turns...  1 short fat  stranded coper wire
