Is Lindsay?s ?SM? a fraud?
Started by RobotHead, May 19, 2008, 11:55:42 PM
Antimon
Quote from: Chef on October 12, 2008, 02:26:01 PM
Yeah,but tell me how that will explode my house?  You just talking, but not answering my question.
House exploding is totally bullshit! Of course, you can die, or hurt yourself serious,but you will not make dust from your house in a microsecond. It will not happen!
omg, boy, i just said that......get your thing work and try it, then you will know
A.
angryScientist
Hi all,
Sorry I haven't been too active. Life has lots of demands.
Could anyone tell me anything about the subject of Q value has to do with this device? I mean it is a coil so it does have a Q value. I have not seen anyone talking about how to construct this thing and address the Q factor.
The Q factor is affected by the resistance of the wire, the self inductance and the self capacitance. The higher the Q factor the more power the coil will store at resonance. The power that you put into a coil at resonance will be stored in the capacitor and inductor. therefore the voltage between the capacitor and inductor will be the the input voltage times the factor of Q. The amperage will multiplied by Q also. But, this is suposed to be a hidden power and can't be tapped directly.
Thank you for your thoughts on the subject.
By the way, I have been a HAM since I was 11 years old so I do have a little for familiarity with electrical and radio theory than the average bear.
BEP
@angryScientist
From one HAM to another:
You'll have to read the alleged commo with SM. Keep in-mind where thoughts lead to the idea of resonance and Q they probably don't fit conventional thought in LRC circuits. By 'conventional' I mean by the book and narrow minded. It is possible to 'null' a set of coils only in the high audio range of the spectrum. Whether that pertains to a TPU or not I can't confirm until I have one that works  ;D
I've been a brass-pounder for quite awhile. It has only helped a little, later. At first it made this trek more difficult.
Thaelin
   So what you are getting at here is the power gain seen in the coils is the reflected power in the coils. Then if you have a pick up coil
around that coil, will it not see the level of the gain and not the input signal?  The more I see this, the more I keep seeing a pair of three
phase windings overlapping to cause a rotating center field. If done like the RV, the cap will make the other half of the phase lag by 90
degrees for each winding set. That makes 4 phases of 90 for 360. Only diff is the speed at which the rotation is happening, say 5000?
Then  the "pick up coils" see a lot of action. Seems I remember two big caps on the 15". Something to ponder here.
thaelin
Quote from: angryScientist on October 13, 2008, 12:53:18 PM
Hi all,
wattsup
@Thaelin
The LTPU big black caps are in series. Would that change the phase issue.
