Is Lindsay?s ?SM? a fraud?
Started by RobotHead, May 19, 2008, 11:55:42 PM
angryScientist
Hello all,
In the picture of the two small toroids you have been talking about two wires, one white and one black. This looks very familiar to me.
The last toroid I wound looked some what similar to that. Only the second wire I used was not a wire at all. It was a non conductive line used as a spacer. I had to use a spacer in between each turn to keep the turns separated as much as possible. I sure didn't want the turns to touch as that would increase the self capacitance of the coil. Self capacitance in a (high frequency) coil is BAD!
I would suggest that the white "wire" is not a wire at all. It would be an insulator used only to separate the individual windings.
sparks
   Looks like those black wires are square.  Could this be a cannibalized magnetron core?    His starter magnets then bend the electron emission and starts a field a spinning just like a magnetron does.  Difference is this one is big and the lctanks are setup to be resonant at 5khz.  The gain is produced by the weakmagnetic field of the Earth keeping the spoked field a spinning.  Magnetic tornadoe of sorts.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
Anothertruthfinder
Hi all aka eel here  ;D, sorry about the slightly off topic idea ive got but i just have to get this out somewhere,
i took one binatone 'walkie talkie' - i think 443mhz - and previously to this i had made a quick basic 'charge pump' circuit (Tate ambient power module or the 'free to air electricity' circuit), i was getting interesting result from a sound card on my pc with frequency gen software so i found it liked high frequency to 'excite' some voltage through the module managed to get about 40 volts from a 4 volt output and light loads of leds, anyway moving on to the walkie talkie, i found out that transmitting right near the diodes in the circuit i could induce a good 26volts at 40 milliamps peak enough to light a homemade 12 volt 48 led array near full brightness! i checked to see how much power the cb was drawing away from the circuit - 4.5 volts @ 80 ma, lighting up the leds 4.5 volts @ 85 ma, so logically i get about three quarters of a watt back from about 350 milliwatts! - shades of tesla bigtime! (wardenclyffe tower) - what if i put ten charge pumps in proximity of the aerial and fed a loop back to rechargable batts and powered a load? - im seriously investigating this matter - it partly seems to good to be true but maybe tesla knew exactly what he was talking about. if i put a large solar panel up am i making the sun work harder? if a million people tune in to radio 1 does the station feel extra drain? not as far i know. now it was mentioned that steven supposedly started these devices and it took a little time to charge but would self sustain there after - caps? and the ring kept the signal focussed and channelled perpetuating til thermal runaway took over? trying to do a jigsaw here i guess hehe
ill keep you posted about proof of concept. loads of potential i see here
also ill put some circuits and values and pics up soon as if ya all like?
catchya soon, take care
eel
MACEDONIA CD
hi to  new   man up herewhit  rf transmiter ;)
   I HAVE  SAY LONG TIME AGO  FOR SOME  LIKE YOU SAID <IF I HAVE 1 WATT RF AMPLIFAER  WHIT SOME  STABLE FREKFENCY LIKE<PLL SINTYSAID FREK.>
  AND  THEN I PUT  LETS SAY  1MILION  RECIVER TO THE SAME FREK . OF THE  1 WATT RF AMPLIFAER>
DID  WHILL BE  EXPLOAD THE RF  AMPLIFIER????
NO
EXPLANE  <1 WATT  RF AMPLIFAER IS NEED TO > ONLY FOR DISTANECE FOR   TRANSMIT FORCE IN THE EAR 1WATT IS  DISTANCE OF TRANSMITE
BUT I   made mysefl rf amplifaers more biger and i know how is working  but i dont have yet  test  didi i whill get more  the  transmiter energy
ABOUT 10 YEARS AGO I HAVE MAKE   50WATT RF  FM TRANS.  AND  i put antene <dipol >out  and  i get   simple  analog mesurment   and  i see some force moving the  nigle of analog mesurment  whit out eny conection >
that was for me   insparation how is  this   strange efeckt  hmm but that was long time ago
then i have make   simple reciver  whit only diode  and coil  and opss i get 0,2v max   to  load  150 ohm load there
hmm <GREAT THINGS  >but i have   need  to get more power  like   10000000 diode  recivers to make  >but no to much
<<<<<<<<<<<<<<<<<MAST BE EASY WAY TO MAKE  THAT > NO TO MUCSH RECIVERS >
THEN  then   i have find   for first time << T.P.U> OF THAT strange  secret copy many   <Steven Mark>
                    yes  t.p.u or  generator whitout eny moving parts   <made long before the <Steven  Mark >  reborn   mystery
<<MAN  IF YOU  HAVE ABLE TO TEST THIS WHIT  RF TRANSMITER IF YOU WHANT  THE  RF AMPLIFAERS SHEME I WHILL HELP YOU TO MAKE THE AMPLIFAERS  <BUT  I CANt   HELP YOU  WHIT BYING THE  10000000 RECIVERS DIODE   TO  MAKE SIMPLE TEST
I                 I LIKE TO SAY  SOMETHING ABOUT  SOME  DOCUMENTARY I HAVE WATCHS LONG TIME AGO  IN THE TV.<< i dony remember where is beang this  test make  but is beang like this
  small plane  whit 100watt i thing has beang  elktromotor  for  that small plane  whit remote control
that plane  has  no  have eny batery or eny kind fosil fuel   ony  reciver  ho pick up enrgy  of some transmiter and <THE PLENE IS  FLYING  >WHIT NO ENY KIND   FUEL  >
THAT WAS OF IN THE TV DOCUMENTARY I HAVE SEE LONG TIME AGO
I THING IS  GOOD INFORMATION  WHIT  RF TRANSMITER>
<<PS if you whant  the sheme for rf amplifaers  im here    i know how is  to make  <rf is complicate  divices for  tune  and whit out harmonics  >i work long time whit  that stuff <<YOU ONLY FIND 10000000 RECIVERS DIODE AND MAKE TEST ;) ;) ;)    :D :)
sparks
    Welcome another.  You got the jist of things.  The rf catalyzes disresonance of the mass emwavefield it encounters.  Reflect the rf enough times through the mass you get a standing wave field with voltage nodes that end up on your output terminals.
Think Legacy
Spread the Love
