Is Lindsay?s ?SM? a fraud?
Started by RobotHead, May 19, 2008, 11:55:42 PM
Antimon
Forget the magnetic field, we don't need it in this case. The ether shockwave is happening before the magnetic field builds up. The magnetic field should be as low as possible to save input power.
A.
Spider
@Bolt,
Is this the configuration you mean?
Spider
When a magnetic field, produced by a moving electric field, is moved longitudinally a tempic field is produced.
turbo
Quote from: BEP on October 25, 2008, 12:10:14 AM
For those that think they can rotate a magnetic field, magnetic flux is generated by a magnet or coil, field lines/layers or laminations are the normal makeup of magnetic flux, I am sorry. Your opinion will likely never change so I'll leave you to your travels.
Well said BEP.
The fields are stationary.
Quote from: bolt on October 24, 2008, 10:55:37 PM
You keep telling me you cant make rotating magnetic field yet this circuit does exactly that.
Can you explain to me then how exactly this magnetic field is rotating?
How can you move something that is proven to be stationary??
Marco.
wattsup
@BEP
Since this is AC won't the coils change polarity at every half cycle thus the inside will be receiving a north then a south field and not a steady field rotation. Was this not made to keep a rotor in forward rotation by simply alternating the applied field.
@spider
Your design looks like Ottos ECD but in dual layers.
Antimon
You can only manipulate the field strength in regions and this is what happens in a 3-phase motor too. The rotating motion is only virtual, When you look at the rotor the field is stationary, you only move the "magnet" over the stator.
A.
