Is Lindsay?s ?SM? a fraud?
Started by RobotHead, May 19, 2008, 11:55:42 PM
bolt
"only manipulate the field strength in regions"
i know that thats what i want.  BUT the action on other magnets or magnetic  waves or even a tin can is rotation. So you will see the compass spinning like crazy in the center thats what we want thats what SM told us to achieve. THEN you make 2 of them and then we have a ball :)
There is a youtube vid somewhere i cant be bothered to look but a guy has a 3 phase motor casing open no stator he throws a beer can in and it spins up 1500 RPM and flies out.  This will produce circular polarization as it interacts with the earth field. I think your missing the point im not looking for a direct local effect this its precursory only. The real action is out in space beyond the TPU. By  transmitting you shall receive. Its only the first steps to making a TPU. If the compass spins this simple TPU has got further then ALL the other TPU's unless you show me one i missed.
MACEDONIA CD
hey  how to put   pic. here  is  1MEGA
Spider
@mac
put them in the download section
http://www.overunity.com/index.php?action=tpmod;dl=0
@wattsup,
I see some simularities yes
@bolt
Do you have some personal building experiences with this setup you want to share?
Spider
When a magnetic field, produced by a moving electric field, is moved longitudinally a tempic field is produced.
BEP
Quote from: wattsup on October 25, 2008, 07:10:51 AM
Was this not made to keep a rotor in forward rotation by simply alternating the applied field.
Exactly. No rotor = no rotation. Even if we think the normal rotor-type rotation is needed the target is missed.
My understanding of the description is a single ball rotating on two (2) axis. If you want to throw in a can to watch it spin then this will work, I'm sure. What if you don't want it to be ejected out the end but continue spinning and ALSO rotate end-to-end?
As far as Wiki goes.... yes they do a pretty good job. They blew it on this.
I don't waste much time anymore on the magnetic. IMO it is only there to give me control over the electric.
sparks
         Below is a diagram of a cryptic Tesla transformer with an SM collector winding up through the middle.  In a coil of highselfinductance the magnetic field surrounding each turn induces the current in the next turn so the magnetic core inside the turns sees a "traveling magnetic field".  So doesn't SM's collector winding.   Notice that the capacitor is attached to ground and a voltage collector at the top.  Also notice that the spark gap is inbetween the capacitor plates.   This is basically creating a voltpile with the earth and the ionosphere as the outside collector plates.   Spark gap inside a capacitor inside a capacitor.  Also notice that the primary is a coil of low self inductance so it radiates the spark gap voltage information very quickly (speed of light quick) to the secondary.  Not alot of chance for backemf when you radiate the primary information in.  This basically is converting the velocity of an emwave into a much slower emwave.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
