Is Lindsay?s ?SM? a fraud?
Started by RobotHead, May 19, 2008, 11:55:42 PM
innovation_station
Quote from: Grumpy on October 31, 2008, 09:11:21 AM
Notice that SM says "revolving field" but not a "magnetic field".
So, If you have a device that you think works and no inertial effect - then you should take another look because it probably doesn't work like you think it does.
"Kicks" are what you get out - not what you put in.
kicks are what fill my caps...  the rotating feild that sm speeks about is most likely the bemf beeing speeded up
there a million ways to achive free engery
here is 1 way sm could do it ... from his control coil he makes an magnetic feild over the collector wich is thick wire and stout as tesla would say and that magnetic feild squeezes the collector ...  induceing current in it ...  when you colapse the feild ....  the kick returns 2 places.....   1 in the collector and this is what you revolve to create your inertia and the other kick will apear at your switching device wich can be used as tesla teaches in the ozone pattend to self sustain or cut way... back on input as bendini motors use....
some of my coils will work this way...  not my current coil ...   it is a normal generator .....  and a + pump and a bemf haverstor ....
that is all...  all i did is utilize what my kick coil already makes 4 free  ;)
ist
Thaelin
        And a partridge in a pair tree     ;D
thaelin
Quote from: bolt on October 31, 2008, 08:58:44 AM
"IT DOSENT MATTER IT IS THAT SIMPLE JUST AS SM SAYS!!!"
Simply constructed maybe but technically very difficult to get working. Unless you have 2 collectors and 3 oscillators driving 3 gate coils each to give rotary 3 phase-NON reflective AND quench the collectors at 6 kHz with skewed  H B bias for the saturable reactor  mag amp (toroidal core and magnet) then you don't have a 3 Phase PUSH PUSH Magnetic Triode Amplifier that will automatically provide DC across the collectors with 6Khz AC sat on top with open loop gain>10,000 then you don't have a TPU you have a coil banger.
ALL the early versions of TPU had toroidal mag amps but i not seen anyone use them yet anywhere on this forum. If i missed one let me know;)
starcruiser
@IS,
Have you tried to use a LC tank design in the input circuit? I am sorry if you mentioned this prior I did not see it. I believe doing so would greatly reduce the input requirements as to current. You could then use a smaller power oscillator to feed the input LC to keep it topped off, the oscillators operating frequency could then be a harmonic of the actual LC resonance (6Khz~ anyone?) to keep the parts cheap. The output as I think you are using would then use a diode plug with caps (resonant again to increase COP) to tap the output for work.
Is this similar to your concept? you can IM me if you choose if you do not want to publicly disclose.
Regards,
Carl
innovation_station
i add this ....
http://www.youtube.com/watch?v=rEaJnoq_ngU
between both thease times i drew a really thin line ...
its nothing i planed... and not that i can...
but you should be mine ...  across that line...
if i trade  it all ...  if i gave it all ...away ...for the... one thing  just for the ONE RING ;)
if i sortted it out ....  if i knew all about this one thing
WOULDNT THAT BE SOMETHING
i promise i might not walk on by.... maybe next time .......BUT NOT THIS TIME
ist
bolt
100% true "Kicks" are what you get out - not what you put in." I been saying this for 2 years now stop putting kicks in there is no need you only need 10 millwatts sine waves to get it working. It don't kick though this is 3 phase it STREAMS pure cold RF = RE beuase the 3D hole created is constantly fed to try and block it. Because RE IS RF you will get RF type burns and RF green streaming flashes yet at the same time its DC. Why? Because its a magnetic triode and and triode SELF rectifies thus no diodes required electrons will flow creating a positive and a negative side automatically.
Kicks are tesla and bedini toys it has very little to do with the TPU.  Thats why when the TPU starts it winds up slowly as the oscillators take effect. The exact dynamics of whether its a magnetic, particle, neutron or electron spin is really not important as the very same thing can be argued about what really rotates in a 3 phase transformer or motor. Quantum mechanics no doubt describes the process very different to electronic or conventional electrical engineering. You can argue this point long AFTER a tpu has been made it wont solve the principles. Fact is 3 phase motors do have a rotating field and there are circular polarized antennas.
SM lessons are important he is not hiding anything.  Every step must be completed to reach the goal. Every tick must fit no excuses. Every story is a lesson he describes magnets, radios, oscillators, frequencies, purity, 3 channel hi fi, circuity, RF, stability, PCB's, feedback, rotation, magnometers, vortex and even 6KHz spot frequencies, hash and AC DC mixing, other based on the circumference of the coil. Gives instructions of construction, collectors and control grids coils even cold cathode  triodes. SM has given an incredible amount of information here but only 5% really can grasp the concept and it goes WAY WAY further then coil banging.
What is the result IMO = Three Phase PUSH PUSH Magnetic Triode Amplifier quenched 6Khz.  Whats in the box? 3 off 555 type oscillators, comparators for feedback control and 6Khz quenching control to drive the mag amp on a bit of PCB. If you had the circuit you could build the controller in an evening and buy the parts from Rat Shack exactly as others said in the past there is no CPU controlled stuff in there its more like a radio then anything else.
PS the other posts are skewed now to my way of thinking and it will appear everyone else had the same idea all along:)
