Is Lindsay?s ?SM? a fraud?
Started by RobotHead, May 19, 2008, 11:55:42 PM
wattsup
@sparks
I looked over that patent with some other guys here back in 2007.  Totally crazy.
Have you seen this one. I am sure you will like the patent title.
http://www.overunity.com/index.php?topic=962.msg47997#msg47997
Just click on the pdf file.
zapnic
Quote from: Grumpy on November 03, 2008, 06:05:51 PM
Actually, I believe the sweet spots for this sort of thing are in discrete steps - similar to the Barkhausen effect.
..but the Twighlight Zone sort of description is far more entertaining...
hmmm i was wondering if" mix tesla radiant energy device to barkhausen effect"or that energy from thin air setup ????
hmmmm ??? ???
bolt
Quote from: giantkiller on November 03, 2008, 06:02:59 PM
If the freq is applied to the highest expected Q out of the collector then the Q is not only mirrored but magnifies to the heterodyned output of the control coils. If highest Q is approached the DC output will go up which equates to a bigger mag field. This adds to what we are already pumping in for spin. That is where the bomb effect comes in. The mention of 555 comparators is vitally important.
Why the ramp up on TPUs? Sloppy start up Q. Dual sideband operation. Pure genius! The unit then systemizes itself for self induction to Hi Q operation. The comparators then do their work and fluctuate the unit to sideband operation. Otherwise we are just tapping the bath water and sending a tidal wave over the edge. ;)
--giantkiller.
GK   Q is everything for coil OU circuits. The gain is 1.618 * Q and applies to all motors and coil bangers. Bedini and Newman RV etc all work hell of a lot better when you use BIG ass motors and coils because Q goes UP. So how do you make a little TPU appear BIG?  and the answer is said a million times already QUENCHING. In fact if you study the followings of RV someone found that when you SHORT the coil on peak Current sine then open again 2 milli seconds later it creates a ring back and dramatically increases Q and genset output goes up MUCH higher.  Its a bit crude but in effect he is quenching the motor coils and preventing current formation.
wiki = uses a second lower frequency oscillation (6Khz TPU)  (within the same stage or by using a second oscillator stage(mag amp TPU H B skewed bias via magnet) to provide single device circuit gains of around one million. This second oscillation periodically interrupts or "quenches" the main RF oscillation, allowing the RF signal to be built up over and over. Strictly speaking, the main RF oscillation still occurs: the detector starts to build up the incoming RF oscillation up to and slightly above oscillation level. But the net result is that most of the time the detector is amplifying the RF signal and is creating a free running RF oscillation in only a small portion of its quenching cycle.
Without quenching TPU Q will be around 50 maybe less as its effective antenna area is microscopic compared to ELF Earth Scaler Wave mag field. Thus you can bang away till the cows come home wont get much happening unless you use REALLY high power levels to drive it like 100 volts at 10 amps. OR quench at your input oscillators only need to be 10 milliwatts and run off a little 9 volt battery thats all thats required.
This is why when the TPU turns on its not instant power the quenching needs to build up the Q state in the collectors before it starts to work this will take several seconds. By taking control of the mag amp reactor you have perfect control over the TPU without it running to vaporisation.
Grumpy
Quote from: bolt on November 04, 2008, 06:06:51 AM
If you open a shorted coil 2 milliseconds after shorting it, then you are interupting current rather than preventing it.  The electrons begin to flow withing nanoseconds of making the connection.
100v?  Then you have no idea how it works.  Ever hear of dielectric flux?
You do not need a scope, or fancy equipment.  You get off your ass and start building and tune the damn thing while observing the results.  Did Tesla have an oscope or even an oscillogram - no he did not.
        -Frank Edwards
sparks
      This patent is two particle accelerators interacting with each other.  It uses magnetohydrodynamic (plasma wave field) particle accelerators.  The plasma field is pulsed so as to create a wave that rotates around the torroid and can actually close in on it's own tail.  The waves are initiated in the two torroids in counterotation which creates two electrical vortices that are relavent to each other and the aether.  The electrons surfing the plasma waves longitudinally are at  different energy densities and are electrically relavent to each other.  Beyond that, if looked at on a relativistic level, can be driven so that the electrons are at different speeds of light.  This opens up a whole new can of worms. ???
     Electrical vortices are pretty powerful stuff.  Google electric vortex sometime and look for what happens when two magnetic monopoles become coherent.
                                  http://www.rexresearch.com/stclair/0301970.htm
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
