Free Energy Revealed - Magnet Battery
Started by 0ne, May 25, 2008, 09:14:52 PM
tinu
@0ne
No offense, 0ne, but it looks to me like you were deeply brainwashed by ?magnetic currents?, ?magnetic batteries?, ?cold electricity? and other esoteric and crappy stuff. Either that or you are just a guy trying to collect donations?
Regardless, you?ve just discovered the regular chemical battery: magnets are not necessary, water in ANY piece of paper (or ?dielectric?, as you call it), no matter how little water it is always there and two metals. Voila.
I?m sad to let you know Volta (1800) was quicker. Apparently the Egyptians knew about it too.
Not farther than current forum the subject was debated several times during last year only. Elsewhere on the net you?ll find it clearly explained as well. So, are you collecting donations or what?!
Cheers,
Tinu
0ne
tinu, no I am not collecting donations. Actually the only reason I have a donation spot availible is just incase someone nice comes along.
Also, you are WRONG.
This is NOT a chemical reaction.  I get voltage way before I add any water.. Also, I took the magnet away, and I get nearly zero volts. The magnet gives me volts, and the water/dielectric gives me amperage. The amperage was always there, just not enough to be read by a device. Water both jumped the voltage, and the amperage.
It seems the VOLTS are coming from the magnetic force, which is where electricity comes from. Electricity doesn't exist, it is only magnetic force.
This is NOT a chemical battery reaction, I'm sorry to disapoint YOU.
I do not need water to make this work... I only needed water to make you people happy when you were asking for amps.
Read Ed Leedskalnins work. He shows you how he can load energy into a U loop, walk away for serveral months, then come back and take that energy out. No matter how long he waited, the same energy is outputed. The way HE describes getting the magnetism out, is by simply taking the "keeper" off of the U and having a Coil near by to pick up the magnetism as it escaped.
I am showing you the same thing, you can load magnetism into a U loop, AND I AM SHOWING YOU HOW TO GET IT OUT! (well one way, there are multiple ways).
Please answer me, are you familiar with Ed's Perpetual Motion Device?
wattsup
@One
Where have you been?
Are you leaving the meter probes on the system. You should remove them while you are waiting for the voltage to rise, then only put the probes on to measure the voltage, then remove them again. You can get voltage through the meter at the mV levels you are talking about. Also, is your battery in the meter new. If the battery is getting low in the meter, this could also cause some bad readings.
On your web site, you should change the color of the linked texts. Blue on black is very hard to read. Maybe also increase the font size. Good read. I'll have some questions for you on what you have put forth, with thanks.
0ne
Quote from: wattsup on May 26, 2008, 10:34:54 AM
@One
Hey, I have been busy working on anti-gravity. Nice to be back...
I usualy only tap the probes on the system to check. The last test in the video though was left on over a long period, because I wanted to see the values drop. But the way it was sitting, and setup, it was only gaining over a long period. Which doesn't happen with chemical batterys. Also, I have two meters, both with brand new batterys. I also have a universal ac/dc adapter that I can plug my multi-meter's into so I don't have to worry about bad readings from dead batterys. My meter is solid, it is not giving me funcky readings..
Actually I love this new meter I got, I can directly test LED's on it by sticking the LEDs in tiny bread board like holes on the multi-meter.
Thanks for the tips. I will change the font colors of the links, but the size is about right for my screen/resolution so I think it will just leave it.  A good tip for you is to hold CTRL and roll your mouse wheel up and down (if you have one), this will resize everything on your internet browser.
Thanks again!
0ne
Listen, both magnetism and electricity need to be in "loops" for them to work. It's a fact of life.
Do you know what happens when you short out a 12v battery by connecting a single wire from negetive to positive?
The "electricity" which is really magnetism runs around infinitly in a loop so fast that it starts to heat the wires, and pretty much gets glowing red. This happens quickly because electrical wire is usualy pretty small. What if you replaced that wire with a 1 inch diameter solid iron rod. How long do you think it will take that to heat up and glow red? A long time, if ever...
A U magnet with a "keeper" is a shorted out battery! It doesn't glow red because the metal is thick. Also, because of the permeability of the metal, the magnetic domains are aligned just right for the metal to act like a superconductor. So the "electricity" or magnetism can flow through with very little resistance, meaning no friction to create heat.
b.t.w. I have scientific experiments you can do at home to prove electricity is two different forces... not 1.
