Bendini motor to run itself
Started by chuckage, May 29, 2008, 09:23:50 AM
chuckage
I don't know much about the bendini motor, so please tell me if I'm wrong and help me understand.
If the bendini motor can put out more power then it takes to run, then why cant you connect it to itself and have it run off it's own power and still charge something else?
forest
Good question.I would refine it further : why not charging discharged battery while powering the circuit with the same one ? I bet a discharged battery even at 11V would have enough power to turn wheel ...
I think it can be done but amount of RE generated must be many times larger.
pinestone
Quote from: forest on June 02, 2008, 06:24:24 AM
I spoke to my brother-in-law yesterday & he was describing his recently built Bendini motor to me. I could hear it running over the phone...
He is using a typical 9V battery (from a smoke detector) to run the Bendini, and it charges a 12V UPS battery.
I asked him the same question...why can't you take some of the output and feed it back into the input?
Wouldn't a couple of low-voltage drop diodes work for isolation and direction?
bourne
Hello guys, my first post in a while :)
The quick answer is no you can't charge the battery that is running the machine. Why ? because they simply don't like it.
There is but one true power in the Universe... that which we call Love. Todays present label and conspicuously absent from our named guardians tool kit.
pinestone
Quote from: bourne on November 20, 2008, 05:15:46 PM
I can see why you haven't posted for a while. You have nothing useful to say.
