Cancer cure, but FDA and doctors would rather have your cash and not the cure.
Started by b0rg13, May 30, 2008, 07:59:29 PM
amigo
Hi triffid,
From what I can understand in Lakhovsky design, the wire is a resonant tank, formed from the loop part being the inductance, and the overlapping part forming the capacitance. Are your coils not overlapping at the ends at least inch or two?
In a configuration I described above, there is a definitive CW / CCW direction depending how you overlap the wires. Further more we could probably compute resonant frequencies, based on the length of wire and perhaps measure inductance and capacitance as well.
For example a quick measurement of the coil on my right wrist (hey I got one each on my wrists and ankles ;) ) shows about 0.27uH inductance and 19.4uF capacitance, with a length of 9-3/4" and an overlap of 1-3/4".
If we apply a basic LC tank formula (just for the sake of example, it might not be correct) we get
Or we look at the length of wire, which is 0.24765m, the frequency of that full wave is
Either way there are some numbers we can retrieve from this and work are way through deduction...
What I'm trying to say is that for everything must exist an explanation that is based on knowledge and not belief or mysticism. :)
professor
Quote from: amigo on October 28, 2008, 10:28:37 PM
Hi triffid,
Amigo my good old friend how are you,
Very interesting Subject and I am not here to bash or criticize you,just to get something obvious cleared up.
As you know I am a Radio Amateur and have been playing with RF circuits pretty near all my Life as well as professionally.
I did not do the Math and frankly I do not want to get into that either, but as I said, it is obvious that 1 3/4 inch overlap can not produce a Capacitance in the uf Range especially a round Conductor. Even using  two plates you are looking in the  very low  pf ranges.
To demonstrate that look at an old tuning Capacitor used in the old Tube or early transistor  Radios,if my memory serves me right they were 565 pf or thereabouts and had many plates spaced very closely and were about 1 3/4 inch in lenghth as well.
This of course would change your Calculations drastically.
Just my 2 cents worth
professor
amigo
Quote from: professor on October 29, 2008, 02:29:00 PM
professor
Greetings professor,
You are absolutely right and your comments on this are worth $2 not 2c. I have realized my error last night when I went to bed and gone through the deductions on the whole issue. It appears that there could not be a capacitance of that magnitude in the coil and that my meter was just acting up.
For the sake of my education, how would one even determine the capacitance; is the capacitance formed by the overlapping part at all; or if there is any to consider?
I will have to revisit Lakhovsky's writings again and this time take notes on what he talked about regarding the sources of energies and just resonant circuits in general relating to his discoveries.
professor
Quote from: amigo on October 29, 2008, 10:14:44 PM
Hi Amigo,
Glad you did not take any offense, I am saying that because I had been getting so much flag for my comments which were always meant in good faith at first but if I do get a quirk I return one.
I think you are right in your assumption of not paying any attention to the capacitance ,I think its mere of mechanical nature
to allow for flexing. A loop like that and it depends on your belly circumference would likely be resonant in the VHF to UHF Full wave  Range. I have an antenna Analyzer  which could shed more light onto the exact frequency, although I think going into that Direction one is waisting its Time. Copper Bracelets of much smaller circumference work , as being claimed. Different size i.e. different frequency.
Cosmic energy , I am taking a long shot here is of a broadband spectrum like Light. Why it works or supposed to ? I don't know  I think its everyones guess for the moment.
Professor
amigo
Hi Professor,
I would not take offense whatsoever, no matter what. After all these are only words, it is the meaning that we put to them that matters, and sometimes even that does not come across well over the Interweb, being the sterile media. :)
I somehow suspect that all this Cosmic Rays business somehow connects to Radiestesia and Dowsing, which Lakhovsky was "into". Of course there's not that much practical science explanation of Radiestesia available in the West. I am sure there are volumes written in the East (Soviet Union had institutes with real scientists researching the paranormal and alt. sciences) but nobody translates those books because over here think they have no value or something. I guess I should just learn Russian...
