Japanese Company Has A Car That Runs On Water.
Started by ResinRat2, June 13, 2008, 11:28:43 AM
hartiberlin
Hmm,
seems to be some kind of new fuel cell :
http://www.genepax.co.jp/mechanism/system.html
There is water split and then electrons extracted and they somehow need
only O2 from the air and water for it...
Hmm...
can somebody tell us, how the chemical formulars are for this ?
Many thanks.
hartiberlin
Can somebody who can read Japanese language please translate these pictures texts ?
http://www.genepax.co.jp/img/cell.jpg
http://www.genepax.co.jp/img/stack.jpg
Many thanks.
ChileanOne
While discussing this in other forum somebody stated that this one uses the aliminum irreversible reaction, but he did not say if he read it into the site or assumed it by the lack of information.
Not whistanding that, I am really skeptic about this, because this company would not be advertising this invention only for automotive purposes, if it works for a vehicle, it would be revolutionary for everything else.
ChileanOne
Using the Google Languaje tools, I can see that they don't really say much about their System. But I realized that they made the car only as demostartive product, and they indeed intend this to be the energy of the future.
ã,³ãƒƒãƒ—1杯の水が地球ã,'æ"¯ãˆã,‹ã,¨ãƒãƒ«ã,®ãƒ¼ã«ã€, 1 cup of water to sustain the energy of the earth.
    * トップペーã,¸ Home
    * 企業æƒ...å ± Corporate Information
    * ニューã,¹ãƒªãƒªãƒ¼ã,¹ News Releases
    * ã,¨ãƒãƒ«ã,®ãƒ¼ã,·ã,¹ãƒ†ãƒ  Energy System
    * メã,«ãƒ‹ã,ºãƒ  Mechanism
    * 開発実績 Development experience
    * å°Žå...¥ä¾‹ Case
    * 採ç"¨æƒ...å ± CAREER
    * お問合せ Contact
Energy system "WES" (Wes) is
    * WESとは WES is
    * 燃料電池とのæ¯"較 To compare fuel cell
    * 5大効果 5 large effect
UOTAENERUGISHISUTEMU (abbreviated: WES) and the current extracted from the water to allow a new power system.
    * 水で発電して、電気と熱ã,'作ã,‹ã"とができますã€, Power and water, electricity and heat to make one.
    * 安å...¨æ€§ã«ã,,å,,ªã,Œã¦ã,,ã,‹ã®ã§ã€è¨­ç½®å ´æ‰€ã,'気にしませã,"ã€, Safety is also good, so do not worry about the location.
    * 屋å†...ã,,,地下などにã,,設置が可能ですã€, As well as indoor and installation of groundwater.
    * 水かã,‰é›»æ°—と熱ã,'作ã,Šå‡ºã™éŽç¨‹ã§ã€åŒ–石燃料ã,'一切使ã,ãšã€åŒ–石燃料以外のã,¨ãƒãƒ«ã,®ãƒ¼ã,,使ç"¨ã—ませã,"ã€, Water and heat to produce electricity from the process, without using any fossil fuel, non-fossil fuel energy is used. すなã,ã¡ã€ä»–のã,¨ãƒãƒ«ã,®ãƒ¼æºã,'å¿...要としなã,,、独立電源として、設置場所ã,'選ばず、ã,¤ãƒ³ãƒ•ラ整å,™ã,,å¿...要としませã,"ã€, In other words, other energy sources that do not require an independent power, wherever they set up the infrastructure development is required.
    * ï¼'. 1. 車ã,,,船などの移動ä½"に搭載すã,‹ã"とができますã€, Such as cars and boats to move with the body.
    * ï¼'. Two. 既存の建物ã,,,家に、直ちに設置すã,‹ã"とができますã€, Existing buildings and houses, you can set up immediately.
    * ï¼". Three. 災害æ™,におã,,て、被災地に直ちに電力供給ができますã€, When disaster in the affected areas immediately to the power supply.
UOTAENERUGISHISUTEMU   WES-based electric car
â' ã,¦ã,©ãƒ¼ã,¿ãƒ¼ã,¨ãƒãƒ«ã,®ãƒ¼ã,·ã,¹ãƒ†ãƒ  â'  UOTAENERUGISHISUTEMU    â'¡WES搭載型の電気自動車 â'¡ WES-based electric car
CO2 emissions to zero, KAKEMASEN burden to the environment. The world is sincere call for global environmental protection, clean energy to contribute.
    * トップペーã,¸ Home
    * お問ã,,合ã,ã› Contact
hartiberlin
Here is the explanation copied from:
http://techon.nikkeibp.co.jp/english/NEWS_EN/20080613/153276/
New Fuel Cell System 'Generates Electricity with Only Water, Air'
Jun 13, 2008 19:30
Kouji Kariatsumari, Nikkei Electronics
Genepax Co Ltd explained the technologies used in its new fuel cell system "Water Energy System (WES)," which uses water as a fuel and does not emit CO2.
The system can generate power just by supplying water and air to the fuel and air electrodes, respectively, the company said at the press conference, which took place June 12, 2008, at the Osaka Assembly Hall.
The basic power generation mechanism of the new system is similar to that of a normal fuel cell, which uses hydrogen as a fuel. According to Genepax, the main feature of the new system is that it uses the company's membrane electrode assembly (MEA), which contains a material capable of breaking down water into hydrogen and oxygen through a chemical reaction.
Though the company did not reveal the details, it "succeeded in adopting a well-known process to produce hydrogen from water to the MEA," said Hirasawa Kiyoshi, the company's president. This process is allegedly similar to the mechanism that produces hydrogen by a reaction of metal hydride and water. But compared with the existing method, the new process is expected to produce hydrogen from water for longer time, the company said.
With the new process, the cell needs only water and air, eliminating the need for a hydrogen reformer and high-pressure hydrogen tank. Moreover, the MEA requires no special catalysts, and the required amount of rare metals such as platinum is almost the same as that of existing systems, Genepax said.
Unlike the direct methanol fuel cell (DMFC), which uses methanol as a fuel, the new system does not emit CO2. In addition, it is expected to have a longer life because catalyst degradation (poisoning) caused by CO does not occur on the fuel electrode side. As it has only been slightly more than a year since the company completed the prototype, it plans to collect more data on the product life.
At the conference, Genepax unveiled a fuel cell stack with a rated output of 120W and a fuel cell system with a rated output of 300W. In the demonstration, the 120W fuel cell stack was first supplied with water by using a dry-cell battery operated pump. After power was generated, it was operated as a passive system with the pump turned off.
This time, the voltage of the fuel cell stack was 25-30V. Because the stack is composed of 40 cells connected in series, it is expected that the output per cell is 3W or higher, the voltage is about 0.5-0.7V, and the current is about 6-7A. The power density is likely to be not less than 30mW/cm2 because the reaction area of the cell is 10 x 10 cm.
Meanwhile, the 300W fuel cell system is an active system, which supplies water and air with a pump. In the demonstration, Genepax powered the TV and the lighting equipment with a lead-acid battery charged by using the system. In addition, the 300W system was mounted in the luggage room of a compact electric vehicle "Reva" manufactured by Takeoka Mini Car Products Co Ltd, and the vehicle was actually driven by the system.
Genepax initially planned to develop a 500W system, but failed to procure the materials for MEA in time and ended up in making a 300W system.
For the future, the company intends to provide 1kw-class generation systems for use in electric vehicles and houses. Instead of driving electric vehicles with this system alone, the company expects to use it as a generator to charge the secondary battery used in electric vehicles.
Although the production cost is currently about ?2,000,000 (US$18,522), it can be reduced to ?500,000 or lower if Genepax succeeds in mass production. The company believes that its fuel cell system can compete with residential solar cell systems if the cost can be reduced to this level.
Pictures:
1. Prototyped vehicle
2. 120W fuel cell system
3. Internal portion of the 120W fuel cell stack
4. 300W generation system mounted in a luggage room (left)
