This video pretty much says it all.
Started by KilltheMessenger, June 24, 2008, 01:13:55 PM
hunter
I don't have that deep knowledge like some others, and I don't have a car what runs on demand HHO fully but if I would than everyone on this board would have access to the blueprint. But like I said,  I believe you need a bigger generator to see bigger results. Anyone welcome to correct me if I'm wrong.
KilltheMessenger
Everything I did, I posted to Youtube, There is more to come, good bad, or otherwise.
Quote from: hunter on June 27, 2008, 03:45:26 PM
starcruiser
Quote from: WilbyInebriated on June 26, 2008, 05:25:11 PM
you think rich = better off? LMFAO
one more time for the cheap seats...
you don't NEED AC, you WANT it.  again you confuse wants with needs.
i'm not asking you to apologize for your 'station' in life.
you are adding variables to your experiment that it (your experiment) could do without. are you tracking the ambient air temp? what formulas are you using to calculate how much power your AC robs your engine on any given day at any given outside temp? does the ambient outside air temp remain the same during your entire journey? does your vehicle remain in direct sunlight the entire journey?
reduce the variables, increase the amount of control elements.
oh yeah learn the difference between wanting and needing.
You should also include the humidity as well in the measurements since this affects the performance of the engine as well.
Regards,
Carl
corv
i am still very new to HHO, but what i have noticed with my V6 3.9L is after running about two tanks of fuel through it, the computer adjusted itself and i found myself with roughly a 10% increase. that is reading the mileage from fill up to file up. before HHO was getting 250-260 per tank, anded the HHO and after a few tanks of fuel i now reach 275-280.
Take this info any way you like but even a noob like myself can see that your computer cannot adjust for the HHO if you dont use it all the time
