URGENT! WATER AS FUEL DISCOVERY FOR EVERYONE TO SHARE
Started by gotoluc, June 26, 2008, 06:01:38 PM
0 Members and 42 Guests are viewing this topic.
qiman
To answer 2 questions/comments:
Implosion - yes it implodes when there isn't enough power to make a big enough spark that the Lorentz force accelerates it away from the gap. With plasma ignition experts that I agree with so far from NASA and otherwise, the plasma for a combustion engine in these circumstances will collapse on itself or otherwise called recombination. The plasma is ionized and EXPANDS filling more space. Then if it is still small enough that it is pretty much in that gap area, the free electrons are used for the plasma to "collapse" or "recombine" SHRINKING in volume. That is a vacuum/implosion. Also, my pipe demo...you will get the exact same result with a hex nut around the ground threads on the plug with the depth of the nut barely extending past the ground strap...you will get the same suction effect with the paper. With or without this test, it is a KNOWN variable that the plasma will collapse and recombine rapidly shrinking in volume. If you do not want it to shrink in volume but want it to be able to eject away from the electrodes outwards, you can do it how I did it. Anyway, I posted a few pics in my water spark plug thread...you can see the ejections with and without water.
As a side note...the smaller power blasts that you will see and especially at high frequency, the plasma ball hands just right inside the gap. It is held there by thermionic emissions from the plug metal itself from the current that heated it up. Those are what provide extra electrons, etc... for the plasma to collapse, etc... and are responsible for plug wear because the same parts of the metal take the beating over and over but this doesn't happen if you use enough power to get the plasma to eject from the plug.
Temperature - yes, the plasma is a cold phenomena but when pumping enough joules in a short enough period of time from the low voltage source at a high enough frequency, the plug will get hot. Not from the plasma, from the current. Those 1 cycle per second or so shots I did in my video was enough space in between each pulse and at low enough power, it never heated up...even with 20+cps, never heated. Using my booster cap method and getting fully ejected plasma bursts outwards from the plug, you will make the plug hot..again..not from the plasma...from the current.
This is the video of where the pics came from:
http://www.youtube.com/watch?v=_PGs2Tq_Vfg
gotoluc
Thanks Aaron for posting the extra information on the implosion and also your new video which looks great ;).
@everyone, smw1998a has just sent me his Logic circuit.
Luc
Ursine
I'm doing some pressure experiments with Luc's circuit. I recently shorted out my coil primary. Is it a problem feeding a coil 140+ volts when it's designed for 12-14? How can I protect it?
Thanks,
Dave
gotoluc
Quote from: Ursine on August 10, 2008, 11:17:03 AM
Thanks,
Dave
Hi Dave, I am doing experiments on this at this time and have found that pulsing DC voltage of higher than 48 volts gives no added benefits to secondary output coil. 140 volts would be kind of high but I think but the primary should be able to take it if you are pulsing the DC and have the ability to adjust pulse duration.
I will be posting a new video of a few thing that I have been doing in the next day or so.
Stay tuned.
Luc
gotoluc
@everyone, smw1998a has sent me this addition.
Hi Luc,
A recent addition..
Posted on energetic forum.
Hello All,
Time has caught me again as I have none! I will try and draw the logic circuit schematic tomorrow. Until then, I will just try and explain what it is. The circuit was built for a different purpose, like the charge pump circuit. I just cobbled it in and adjusted it to suit my needs.
The heart of the circuit is a CMOS 4017 decade counter. When the decade counter receives a suitable clock signal each of the ten outputs switches from low to high in sequence and then starts over. These little chips are great for ?Night Rider? type sweeping LED?s etc. The clock signal for this circuit is generated by a CMOS 4047B monostable/astable IC.
What I wanted from the circuit was a means to switch on the charge pump circuit to charge the capacitor for a set time. Then, to switch off the charge pump and initiate the capacitor discharge. At it?s most basic level, the logic circuit?s output is nothing more than a square wave with a fixed 90% duty cycle regardless of frequency.
The third IC is a CMOS 4001 quad two input nor. Two of the nor gates on this chip are configured as a set/reset flip flop. The output of the flip flop goes to pin 4 of the section a timer in the charge pump circuit. The first output ?A? of the decade counter sets the flip flop and this sends pin 4 of the section A timer high, switching on the charge pump circuit. Output pin ?I? on the decade counter resets the flip flop sending the output to pin 4 low, switching off the charge pump. Output pin ?J? provides the pause between charge pump cycles. Hence, the 90% duty cycle.
Output pin ?I? of the decade counter is also connected to an edge triggered monostable. The purpose of the monostable is to light the LED in the H11D1 IC and thus triggering the capacitor discharge. When the output from pin ?I? goes from high to low the monostable lights the Led for the time dictated by its RC components.
Frequency is controlled by the potentiometer in the 4047B?s RC network. Because of the decade counter the duty cycle of the charge pump is always 90% and the edge triggered monostable driving the LED in the H11D1 ensures that the pulse duration is not affected by adjustments to the frequency of the main logic circuit.
As circuits go, it?s not as complicated as it looks and the components are cheap and easily obtained.
All The Best Lee?
Wavorms attached.
Regards Lee....
