URGENT! WATER AS FUEL DISCOVERY FOR EVERYONE TO SHARE
Started by gotoluc, June 26, 2008, 06:01:38 PM
Dread
Luc.
Great job. Thanks for the test data it seems to collaborate that current is there only to create the conductive environment for the high voltage spark effect. Tomorrow, I will cut out the additional 9 diodes from the chain.
If we could somehow split the system to maintain the current but increase the voltage, perhaps with an additional coil, that would be spectacular. Can anyone suggest a circuit addition without the need for additional power supply like Aaron's booster, which I understand is "buggy" if driven by a shared source.
Rgds
D.
It appears I lucked out with my 1N5408's  ;D
gotoluc
Quote from: resonanceman on August 14, 2008, 02:07:45 PM
Luc
Are you sure that   your coil is a stand alone  device?
It looks to me like it was made to work with  an ignition  box like this one .
http://www.msdignition.com/product.aspx?id=5843
To me the most interesting thing about   this  combanation  is  that it fires for 20 degrees .
It seems to me that  firing  20 degrees would take care of most of the timing  problems .
All we would have to  do is  add  some LV  at  the  plug .
Something  other than  a standard  inverter might be needed for   the LV
At  60 HZ  you  would have alot of   HV only  firings
gary
Hi Gary,
thanks for your concern. I think this coil is really designed to work with a driver circuit if you want to use it on a car. I want to do something a little different and hope I can make (build) my own driver circuit just like I did for the Krupa test video. A coil should be a coil, this one will have a different behavior than a standard coil an that could be what I'm looking for.
I have hope :D
Luc
gotoluc
Quote from: NerzhDishual on August 14, 2008, 04:30:51 PM
Hi guys,
Sorry, I have not taken the time to read the last posts.
Perhaps am I 'out of date'?
Anyway, I have made a more accurate as possible replication of
the Peter Lindemann's experiment.
Guess what? It works...
With the diodes (15 *  1N5408) disconnected I get very tiny sparks.
With the diodes connected, the sparks are more important and 'sonorous'.
With a mist of water the sparks are also more important.
When I put too much water the phenomenon stops (not more sparks)..
I Will try with a mist made from an "ultrasonic mister" ??? :
More picture at : http://freenrg.info/Water_Power/My_Replication/
Best
Hi NerzhDishual, great build there ;) . You may want to cut down on your diode string to 7 (see my new video) since you have the 1N5408 and would get a better LV kick. Save the other 8 in case you ever kill the first 7.
You will get great results with the ultrasonic water fog.
Excellent work.
Luc
vlindos
Quote from: gotoluc on August 14, 2008, 06:22:09 PM
@everyone,
I just uploaded a video but I have no time to write about it since I'm now on my way out for most of the evening.
I will answer questions late this evening when I return.
Luc
Video: http://www.youtube.com/watch?v=NvJVbA8Upvs
Luc,
See the attached xls sheet for Capacitor Energy calculations.
