URGENT! WATER AS FUEL DISCOVERY FOR EVERYONE TO SHARE
Started by gotoluc, June 26, 2008, 06:01:38 PM
Dread
Pese,
Yes, thanks for your council. My visits here are becoming more infrequent with development of the engine, test rig, circuit, and high voltage multi-tasking switch, (don't even ask) etc.
The circuit mod. with the V-doubler has increased explosive compression.  @ 30PSI to around 35PSI. I will try with less resistance on the booster side and SS electrodes.
Luc.
I managed to blow my booster diode chain (7 X 1N5408's)  ;D 270uf 400V + doubler was fine. I added 3 x 100uf 400V caps and they died. Using a 12 diode chain now, it's fine but no pressure tests yet.
X-box.
Any idea, why I can't reproduce your explosive compression? Trying to remove variables here. Are you using an automotive HT (high voltage) lead or is it a solid core? Is my 100 ohm resistor too much? Any ideas?
Rgds.
D.
xbox hacker
Quote from: Dread on September 04, 2008, 04:36:56 AM
X-box.
Rgds.
D.
Dont know for sure....i have 50kV wire for the HV, I have NO resistor....also i was using Cap70 Coil design....NO DIODES.
gotoluc
Luc.
X-box.
Rgds.
D.
Hi Dread,
the 7 X 1N5408's diode chain I used in the video demo was in good balance with the capacitor I was using (6.8uf). So if you go with a higher capacitor uf value you will need to add more diodes.
Also for HV wire leads. You must use wire with no resistance!...I had collected some old CRT flybacks and cut off the red HV wire lead and used that everywhere the HV is present. The inside wire is solid and has no resistance. The shielding is also rated at 40,000 volts. It work great for me.
Luc
gotoluc
Quote from: xbox hacker on September 04, 2008, 06:57:22 AM
Hi xbox hacker,
I'm going to try capacitor70's design as soon as I get some free time. I would like to see if there is a measurable power efficiency difference.
I also just notice that capacitor70 has found some kind of self charging 4 battery circuit?... is this correct?... will he start a new topic for this?
Let us know as I'm sure many would like to participate in that.
Thanks
Luc
Dread
I replaced the 100 Ohm with a 50 Ohm and got more bang, then a 20 Ohm and 20 diode's. 1 huge bang then the diode's blew. I think I am totally over the diode thing now. They are fine for lower power but when experimenting with variables they are a pain. X-Box, I can feel your smirk.
It's time for the Cap 70 transformer coil. Where did you guy's get your ferrite core from and what size is it?
Thanks.
Dread.
