URGENT! WATER AS FUEL DISCOVERY FOR EVERYONE TO SHARE
Started by gotoluc, June 26, 2008, 06:01:38 PM
ramset
Aussepom   Also the very high" gas'" production. Please start a thread [or stay here if LUC feels its appropriate}
            Thanks      Chet
Thanks Grandma
Dread
UncleFester
(great name btw)
Thanks for the info. I considered lowering the capacitance but I need it for the sub circuit that I am working on (getting close now) when I get it working, I will publish here. If it works, it will change everything.
In the mean time, I would like to progress with the coil system from the Water Sparkplug forum, but specifics and a general review of my findings will be here.
My sole aim is explosive compression. How I achieve it, Diodes or coil matters not.
Rgds
Dread
gotoluc
Quote from: aussepom on September 09, 2008, 04:04:10 PM
Hi Gotoluc,
Sorry about the intrusion but your thread was interesting as you seem to be trying out with  'spark plugs' high voltage etc, to get a 'good ' spark.
Is this what you want for  the engine to 'burn all the fuel' or are you tyring to produce a 'plasma arc' ?
A spark after all is 'plasma' the same as the lighting, it ionises the air making it easier for an arc or spark to travel in.   But there are other ways to produce ' plasma arc', I have had a thread running in another forum just on this, and some that have read that thread may still be wondering when it will happen.
If you use a high voltage by the way of the ht coil of  a car.
I have used a modified 'jacobs ladder' circuit to switch the input side at 140 to 150hz at about 120v on the 12volt input, but do not let the pulses fall any lower. There were some protective diodes across the switching transistor.
With this you do not need any  gap just break off the small outer electrode, I have had a spark over 1" 1/2 long from this, with a plug it just arcs all over.
I should then if  I wanted to continue on this, start a new thread.
aussepom
Hi aussepom,
to make sure things are clear!... I offered you to post your findings in this topic if you wish, since I think this would give a good head start since many are keeping track of what is going on here. The moderator privilege I have are also useful since I can edit posts. So when you have updates I can post them all on the first page no.1 post so everyone can easily find them.
Just keep in mind that we need the information to be clear and complete (the same way I started this topic)
Luc
gotoluc
Quote from: UncleFester on September 09, 2008, 12:03:52 PM
You need a much longer string of diodes. I've been using two strings of 25 1N5408 in parallel. But each string of 25 seems to handle the massive power we are applying to the plugs. Explosive compression can only be found at levels of energy higher than 3 joules. We found this through trial and error. You cant immerse a plug in water and get it to fire on less than 5 joules, or so it seems through our experiments.
Like Luc said though, the higher voltages help so that you may get away with lower energy levels for the same effect by raising the voltage level but lowering capacitance. Luc's got a great system of running a variac into a microwave transformer. That was a great idea because it semi-isolates the variac and allow a major wide range of voltage levels.
Thank you UncleFester for confirming my findings and the idea of using a microwave transformer with the variac.
@everyone, please be extremely careful with this MOT setup since you can easily reach voltages of over 3,000 volts since some variac can close to double the voltage of your AC input.
You will also need HV shielded wire and to stay focused of all the materials you are using in close proximity of you experiment. This stuff is no joke, it can kill you as fast as a lightning strike :o.
Play safe so you can live to share ;D
Luc
P.S. @ UncleFester, I also like your user name!... it's really catchy ;)
gotoluc
Quote from: Dread on September 09, 2008, 05:33:19 PM
UncleFester
(great name btw)
Rgds
Dread
Go Dread, Go Dread, Go Dread, Go Dread, Go Dread, Go Dread, Go Dread, Go Dread, Go Dread, Go Dread, Go Dread, Go Dread, Go Dread, Go Dread,
May you be successful in your findings ;D
Luc
