URGENT! WATER AS FUEL DISCOVERY FOR EVERYONE TO SHARE
Started by gotoluc, June 26, 2008, 06:01:38 PM
goldenequity
MUCH APPRECIATION....]
to all who donate your time.... and skills
failures and successes..... starting with Luc
without whom this thread and all the circuit variations
would not even EXIST!!!!!!!!!!!!!!!!!!!!!!!
Please.... @ all.....KNOW that this is REALLY an
awesome thing that is going on here..... we lost an important member and contributor
to this thread named Ossie over hurt feelings and poor communications....
very unfortunate.... I REALLY miss him...
so
be kind and respectful and choose words wisely PLEASE.... we thrive on
suggestions, alternatives, encouragement, collaboration, successes and failures,
but not
demands or criticism/belittlement.... be careful.
thanks,
randy
gotoluc
@lapperll
thanks for your reply and the help you have provided to date ;)
@everyone,
who would be up to the task of making the changes to the Nexus circuit as recommended in my post above: http://www.overunity.com/index.php/topic,5024.msg126862.html#msg126862
@goldenequity,
thanks for your kind words and mentioning this very important point. Words do have impact, so let us write softly. That goes for me, as some times I write a little too direct :-[
@everyone,
as mentioned in my above post here is the 220v inverter I purchased. I 'm taking a small risk here ($20. delivered :P) and going for a 150 watts inverter since Bill has said in the video that the consumption was only 100ma!!!... and that was using 120 volts!  so if that's the case I think a 220 volts 150 watts should do the trick. If not I'll loose a hole $20.  :(
Link: http://cgi.ebay.com/150W-Car-Charger-DC-12V-AC-220V-Power-Inverter-Adapter_W0QQitemZ250296515216QQcmdZViewItem?hash=item250296515216&_trkparms=39%3A1
Luc
bwb
Quote from: lapperll on September 17, 2008, 05:17:53 PM
@bwb
The half wave bridge rectifier is just a single diode.  Bill used 5 diodes in series on his circuit but stated that they were not all needed.  Three would more than likely be sufficient.  All you have to do is solder at least 3 diodes together end to end, just like the 60 diode string and the 7 diode cross talk blocker.
I'm not sure about the resistors, maybe someone else can help with that one.
LapperLL
Thankyou for the reply.I hope I didn't sound to much like a idiot.
gotoluc
Quote from: bwb on September 17, 2008, 03:14:43 PM
Expert Needed because I'm not :)
On the Nexus circuit.
1.--Could someone show how to make the three to five 1n5408 half bride rectifier?
2.--If you wanted to use resistors with the 1n5408 diodes what size should you use?
I went to this site and I'm still a little confuse on which way to go. http://www.powerdesigners.com/InfoWeb/design_center/articles/Diodes/diodes.shtm
Hi bwb,
I know it can be confusing when new at this. Believe me this is the simplest it has gotten so far and It took a while to get here. I am trying to help you and others who will come or even those who are here but too shy to post there simple questions so they just keep reading silently in the background so not to interfere with the development and hoping we will post something they can understand.
My hopes are we will come to a very simple circuit and or kit one could buy made or assemble themselves, it is a question of time, sharing and involvement that will bring us there. My hopes are to make it available for close to what it would cost you to buy the parts alone.
To answer your question, there is no resistors in the circuit. Resistors would cancel the effect of the circuit. You also need to remove resistors from inside your plugs or buy non resistor plugs. Video demo: http://www.youtube.com/watch?v=-J2AHNZUZD0
All diodes in the circuit are in series.
I hope this helps
Luc
gmeast
Quote from: Groundloop on September 17, 2008, 07:36:02 AM
All,
Comparing the two circuits is not possible. The Nexus circuit uses the motor ignition and timing as it is.
You just add parts to get the plasma flame at the sparkplugs. Greg's circuit uses reed relays and must
be timed by using magnets on the motor flywheel. It is a more complex circuit and is not for the beginner
if you ask me.
Groundloop.
Hi Groundloop,
What you said is incorrect.  I used reed switches because they were easy.  All triggering hardware uses the distributor's rotor with an optical chopper and gate triggering circuitry ... like one would expect ...NOT on the flywheel.  The circuit I posted was the "exact" circuit I used in the VIDEO.  That posted circuit is NOT the version that goes in a vehicle.  Please don't be so quick to find fault with others' contribution(s) to this effort.
Respectfully,
Greg
