URGENT! WATER AS FUEL DISCOVERY FOR EVERYONE TO SHARE
Started by gotoluc, June 26, 2008, 06:01:38 PM
Quote from: IndianaBoys on June 30, 2008, 09:35:41 AM
Also try it with the http://www.pulstarplug.com/
The Pulstar? Pulse Plug is not just another spark plug!
The Pulstar? pulse plug represents the first technological advancement in spark plug design in the past 100 years!
This new technology is a drop-in replacement for all spark plugs, including those iridium, high performance spark plugs. Pulstar is designed to more efficiently ignite the fuel in an engine's cylinders increasing fuel economy, horsepower and torque. Pulstar? pulse plugs look and fit like spark plugs, but incorporate an internal capacitor to deliver a spark 10 times more powerful than a spark plug with less cycle-to-cycle variation.
Pulse plugs are safe for use in all vehicles and improve combustion efficiency in all spark-ignited internal combustion engines, yielding better overall engine performance, with fuel consumption and associated green house gases reduced by as much as 10%.
IndianaBoys
Aren't they just using a capacitor and a switching diode in parallel. Something like this.
innovation_station
hey guys
how about a magnetic wheel  with reeds and trannys  then the system you guys are working on  out put of that to the ign system
i will do a dwg
ist ;D
innovation_station
@ossie
have you tried to take power from the plug     try to recharge a battery or a cap from the plug  ;)
might blow you away....
ist
callanan
Hi All,
Because it seems that people, who may or may not lack experience in electronics, are having trouble building and replicating the exploding water effect in previously described and shown devices, I have designed, built and tested what I believe to be a very simple to build device that most people can construct themselves at home that is powered only by a small square 9V battery that is commonly used in smoke alarms. I believe even kids can make this. Please see my latest video here:
http://www.youtube.com/m1a9r9s9
The purpose of this device is not to be able to power your car on water with it but simply to allow everyone to see for themselves and show others how water can directly explode on demand with little energy input. The device produces the required discharge in the spark plug about every 1 second and uses about 100-150ma from the 9V battery. At this current level the battery won't last too long but it is fine for demonstrations. For longer and continuous runs, just use a small 12V sealed lead acid battery of say 2 A/Hs.
Please see the circuit diagram and some pictures attached below.
All that is required to build this device is the following.
- A 12V, 150ma Security Xenon Strobe Light. Available from electronic and security stores. Color does not matter!
- An old car ignition coil. Available from automobile wreckers.
- A non resistor spark plug. Available from auto shops. Must not have a resistor in it!
- Five 1N5404 diodes or five large rectifying diodes. Part number doesn't really matter. Avaliable from electronic shops.
- A 9 volt battery. The same as used in smoke alarms. Available from anywhere.
- Some hook up wire.
- Basic tools including a soldering iron and some solder.
- Handheld water sprayer filled with water.
That's all folks!!
Please build this and show it to your friends, family, your teachers, professors, work mates anyone and everyone who can't believe that water can explode. Help your kids build this as their school science fair project. Just build it for fun!
On another note, my very good friend Ben has been doing some great research on this process as there is surprisingly quite a bit in the internet about it. He has found some references claiming that the energy released, when the water apparently explodes, is one thousand times the input energy required to cause the explosion. He has found some great info out about what may actually be happening but I will leave it to him to share if he gets time.
Enjoy!
Regards,
Ossie
