URGENT! WATER AS FUEL DISCOVERY FOR EVERYONE TO SHARE
Started by gotoluc, June 26, 2008, 06:01:38 PM
gotoluc
Quote from: gmeast on February 11, 2009, 08:52:51 PM
Hi everyone,
I posted a new video.  Luc was disappointed in me for not spraying a Firestorm plug with water a couple of videos back so I made this video showing water spray on one of the new nickel Firestorm plugs.
It's short and boring but I hope still interesting for you all.  It's here:
http://www.youtube.com/watch?v=g6Jq_UgWv9E&
Enjoy.  Peace,
Greg
Excellent video demonstration Greg ;)
And thanks for spraying water on them this time ;D
Would you say that the water is reacting better with the Nickel then the previous Beryllium Copper ones?
This was the idea behind trying Nickle, as it has been reported to have a catalytic effect on water.
Thanks for taking the time to post all these great still shots also.
Luc
gmeast
Quote from: gotoluc on February 11, 2009, 11:46:50 PM
Luc
Hi Luc,
Thanks.  I thought you'd like the water-part.  There are several things different.  First I have a newer coil in the bug now ... not special, just newer.  Initially the bug would not run on the new plugs Robin sent.  The only difference was the .090" gap ... Krupa's spec on his plugs.  I was going to send them back to Robin but I really suspected an aged coil.  I swapped it out and "bingo!".  So the gap is the other thing that's different ... that's a huge gap.
I was pleased to see those Flame Fingers in the real-world instead of just on the test bench ... they really are a hallmark of sorts.  I have no way of verifying a catalytic effect, but I think they're better than the stock configs and the beryllium-copper ones.  They have to better if they can produce most of the plasma on their own ... but now I think we'll still need a plasma Circuit to push it over the top.  We'll see.
Take care,
Greg
gotoluc
Quote from: gmeast on February 12, 2009, 01:03:22 AM
Hi Luc,
Take care,
Greg
Thanks for the detailed reply Greg ;)
One thing I can recommend is to test with is a microwave transformer, Primary powered by an inverter and collect from the Secondary the 2,000 + DC volts in the 1uf or less cap that comes with most microwaves and use a 0.25uf cap as discharge.
The inverter should have no problem since you will have isolation between Primary and Secondary.
I know that we all don't like working with high voltage but if we don't try it we will never know if it's what we are looking for.
I tried it once with a 1uf at 2,000 volts dc but no water, my ears ringed for a day, so you may want to use ear protection and most definitely UV protection glasses and thick rubber gloves ;)
I would even recommend you use a voltage multipliers but obviously less capacitance. With 5,000 vdc and a 0.04uf cap (half a Joule) that should give you a great show ;D  You can get a 0.04uf 10KV rated cap here: http://cgi.ebay.com/0-04uF-10KV-High-Voltage-Capacitor-HV-Tesla-Coil-Ham_W0QQitemZ360104866107QQcmdZViewItemQQptZBI_Electronic_Components?hash=item360104866107&_trksid=p3286.c0.m14&_trkparms=66%3A2
Here is a great online capacitance energy calculator: http://www.electronics2000.co.uk/calc/calcchrg.php
As soon as the weather gets warmer in Canada, this is what I will be testing.
So... are you going to beat me to it?
Thanks for sharing.
Luc
gmeast
Hi all,
Sorry for all of the posts ... can't help it ... I got so excited about the plasma arc-induced D.I. Water electrolysis and ensuing hydrogen-oxygen reaction I put together a short video compilation of the clearest events to share.
It's not big enough to waste on YouTube so you can douwnload it or open it.  It was made with Movie Maker in XP.  It's very generic but much higher quality than gets rendered on YouTube.
http://home.pacbell.net/gmeast/VW/vexus_sequence.wmv
Thanks.  Peace,
Greg
