URGENT! WATER AS FUEL DISCOVERY FOR EVERYONE TO SHARE
Started by gotoluc, June 26, 2008, 06:01:38 PM
alpeko
Answer to Jenkins25
On this link you have many cdi for yamaha motorbike.
Best regards.
Alpeko
link:  http://www.transmic.net/
jenkins25
Thank you very much for your answer, Alpeko.
The link is very usefull and I will try to undestand the concept for make one good and powerfull CDI for the tests.
Best regards :)
alpeko
To jenkins25,
My pleasure.If you have problem,don't hesitate to contact me.
Best regards to all members.
Alpeko.
demios
Pozdrav Kole!
Imam Peugeot 205GT sa starim sistemom paljenja, razvodnik, razvodna kapa itd. Interesuje me da li dovoljna nadogradnja sistema paljenja kao na ovom dijagramu? Tj. da li moram da pravim, kao gmeast, sve one djavole sa tranzistorima ili je ovo dovoljno?
In English:
Hi Kole,
I have a Peugeot 205GT with an old-school ignition system, distributor, distributor cap etc. I want to know whether it's enough to add this circuti from a diagram to my ignition system? In other words, do I have to make the circuit as gmeast did, with all the transistors and stuff?
http://img5.imageshack.us/img5/5928/plasmaeg3.jpg
Description:
Transformer has 1:50 ratio, so it's a step up transformer. It turns 12V from battery to 600V. After that comes the capacitor bank (6 caps) - 630V 1uF (one micro Farad). Then comes the 500ohm resistor, and after that, another 630V 1uF dump capacitor. It goes through 3 microwave oven diodes (12kV) that are connected in parallel, and after that the (+) wire is split in 4 sections and connected to the distributor cap, one for each sparkplug.
Do I need something more here or is this enough?
Thanks a lot!
alpeko
For demios,
Na mojoj semi je Motorolin chip na koji se spaja triger od zavojnice za okidanje tranzistora,koji napajaju bobinu.U principu to ti menja razvodnik,i elektronskim putem prekida primar bobine.
Ovo sto mi pokusavamo da napravimo je usteda goriva pomocu dodavanja napona 300-500 V,koji uz pomoc visokog napona stvara efekat plazme na svecici.Dodavanjem vode u obliku pare(magle),u usisnu granu smanjuje se potrosnja goriva.Gmeast kaze da je na svojoj bubi ustedeo i do 50 %.
Za koji dan ja zavrsavam svoj plasma spark sistem,pa cu da isprobam.
Pozdrav svima.
Alpeko - Kole
In english:
On my schematic diagram is Motorola chip,which is uses for electronic ignition in a cars.
This,what we're trying to make is "fuel saving" with adding 300-500V on ignition plug ,and try to make plasma efect.
Gmeast say that his  VW bugs save fuel for about 50 % with simple oscilator and diode bank.
I working on my CDI plasma ignition system,and I test this in couple days.
Best regards to all on forum.
Alpeko.
