URGENT! WATER AS FUEL DISCOVERY FOR EVERYONE TO SHARE
Started by gotoluc, June 26, 2008, 06:01:38 PM
atlantex
hopefully the capacitor or something else doesn't blow up  ;)
yaz
Video of a sparkplug plasma ball using only 9 volt batteries! Pure DC!
Wonder if hooking up a capacitor and/or inverter would increase the intensity?
http://www.youtube.com/watch?v=_iNCzhP7754&NR=1
hydrocontrol
Quote from: atlantex on June 28, 2008, 01:10:36 AM
Hi Luc,
thanks for sharing your discovery. The european inverters have an output of 230V AC.
cheers
atlantex
Great.. The only problem being that this would be harder for people in the US to get one of these 230VAC inverters so I was thinking getting two 110VAC from WallyWorld and a couple of bridge rectifiers from RadioShaft would be easier. I think getting high voltage caps might be easy as a lot of computer power supplies have high voltage caps in them so a couple of scavanged dead computer power supplies could be the ticket for cheaper replication.
pomodoro
I enjoyed the video but I have a feeling that you have found a novel way to explode water, using an unlimited supply of energy (the inverter). The way I see it, the coil ionizes some water molecules and the inverter is happy to provide the current through the nearly short circuit provided by the ionized water. And BANG! Not much energy would be required to blow up a few million molecules of water. So in a real scenario, you would need to provide more energy than that received by the expansion of the exploding water.
willitwork
If the diagram is correct I presume the 1n4007 would be damaged by now. Can you please confirm if the 4007 is used between the coil and the plug and the microwave between the full wave and the plug. Could they be the other way around?
If the diagram is correct please confirm if the 4007 is still intact.
