Hubbard coil
Started by EMdevices, July 01, 2008, 05:03:36 PM
giantkiller
@mdmiller,
Very cool description. Use MSpaint and draw a top and side view chicken scratch diagram. Just black and white. It is like the little magnets going around. Get it out of your head and down on paper that way the obfuscation or confusion is dispelled. That is how I started out, drawing pictures.
I studied Coral castle for 2 years. When I went in October and stood where he stood I was saw things that are fantastic and not previously documented. For instance: stand on the top step of the North pinnacle and face south. To your left are the planets on the wall. Every wonder why there is only a few? Saturn, Jupiter. When those planets rise in the morning the Sun shines on the north pinnacle. This causes a shadow behind you. The crosshairs make an arc on the ground. Now you have a sextant embedded in a chronometer. The graticle is on the walls opposite the pinnacle. But it is laying down and still usable. Unreal?
When the moon is in the sky above each of the moon phase statues in phase the seats in the park point to constellations. 8)
On the big metal door there is a 'Ring twice' sign. We do that in NMR technology with 90 degree waves. There is a plant on the door at the other end of the diagram from Earth. This signifies life forms at the place. It is 21million light years away in the Goldilocks zone of Ursa Minor.
Well you get the picture: http://www.google.com/archivesearch?hl=en&q=Ursa+minor&um=1&ie=UTF-8&scoring=t&sa=X&oi=timeline_result&resnum=11&ct=title
At certain time of the year all these markers line up. :o
--giantkiller. Are you thought this was about magnets, eh?
sparks
     If the low voltage output of a battery is transformed into a highvoltage highfrequency event that is distributed to primaries of the eight outer transformers.  These transformers then transform this back into low low frequency current.  This current appears sequentially around the core as each of the eight primaries are ignited.  Then the magnetic field would appear to rotate about the core.
In this core we find another transformer of sorts that responds to the magnetic field pulsating about it's periphery.  This winding now powers the motor with pulsed DC.  If there is but a small gain in the spark gap and this gain occurs at high frequency and expressed at low frequency we might get a motor to run off some high frequency gain from the field.   How would one take a highfrequency highvoltage output and change it into a low frequency high current event?
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
giantkiller
The spark gap is a wide spectrum discharge. Set the LC parameters for the low frequency resonant notch you want. Then set the secondary winding of L to a number of wraps lower to get the current you want. Low frequency, high current achieved.
--giantkiller.
sparks
Think Legacy
Spread the Love
mdmiller
hubbard switching ala leedskalnin ...
this image will maybe help explain what I'm trying to say.  in this example there are two PMM's but the continuity of the iron core oscillates between the two(mechanically or electrically). the iron core is only a complete loop on one PMM at a time.
momentary power is applied, the first PMM is charged and active, power is removed and no longer required.  The device is now an electromagnet in-perpetuum per Leedskalnin.  Now, severing the continuity of the core will release the charge on the coils, per Leedskalnin - where he lights a bulb, but instead we release the charge to the coil of the other PMM.
the core continuity could be completed with an iron wire, and by switching the iron wire back and forth, we create resonance between the two PMM's
none of this generates any power, it just resonates the PMM electromagnets back and forth, with no further power input into the coils.  the only energy expended is that required to switch the iron wire back and forth to complete the continuity of a core and activate a PMM, or more importantly deactivate a PMM and thus causing a flow of current into the other PMM and activating it as an electromagnet.
putting these coils into circles, connecting all their leads together, charging an initial coil pair, and then switching the continuity of their iron cores sequentially should rotate the "magnets" and it would be from this magnetic field rotation along with additional coils that power would be generated.
just a thought - duane
