Hubbard coil
Started by EMdevices, July 01, 2008, 05:03:36 PM
forest
Quote from: giantkiller on December 31, 2008, 01:51:28 PM
Hubbard, Mcfarland, GK4, Searl.
The similiarities should be apparent like iron, 90 degree wraps or perimeter situated coils.
The McFarland is missing some connections. Alot is missing elsewhere here.
The Poynting vectors are now coupled correctly. The iron and steel equates to 2 transformers coupled at 90 degrees. The steel and copper equate to 2 parallel transformers. We now have voltage and current out.
There are blocking oscillators and stun gun circuitry in CFL drivers.
--giantkiller.
Yes,McFarland patent pictures have some missing connections, mostly all main circuit is deleted. ;D
But if your read this patent carefully you will realize that others do no use electric current flowing in that circuit at all ! That circuit must remain closed , because it is a generator, and only magnetic field is used when properly shaped into vortex and when the way to use positive feedback is found with proper shunt to disallow an explosion mentioned by Steven Mark.
Let me cite the most important and omitted fragment from MCFarland patent :
"The alternate changes of the iron cores or magnets may be used for producing electro-magnetic motion, or motion to a wheel of any suitable device"
BINGO! It's a special kind of Faraday unipolar generator we are looking for! with magnetic field rotating instead of copper disc.
AhuraMazda
Here is a file which has some interesting information about Hubbard Generator:
http://www.scribd.com/doc/14070044/Free-Energy-Hubbard-Coil
forest
WONDERFUL!  Now it's clear that Hubbard coil and TPU and probably a lot of devices are based on the same principle. Let electrons flow on surface in wave state and recombine later into hard electrons particles. Secondary emmision and speed up by Earth magnetic field.
TheNOP
Quote from: forest on January 02, 2009, 04:10:12 AM
witch one would it be ?
Quotemagnet         disk           external indicating circuit      voltage indicated?
stationary         stationary          stationary                           no
stationary          rotating             stationary                          yes
stationary          stationary          rotating                            yes
stationary             rotating           rotating                           undetermined
rotating            stationary            stationary                        no
rotating                rotating            stationary                       yes
rotating               stationary          rotating                          yes
rotating               rotating              rotating                          undetermined
AhuraMazda
My own current thinking is around resonating the position of  bloch wall in a magnetic circuit.
By fluctuating and resonating the position of the bloch wall, etheric energy is manipulated into action.
Then it is the matter of collecting the energy produced.
A wire carrying current generates a magnetic field. By wrapping the coil bifilarly we create a bloch wall which we can have control over.
I need to do some basic experiments. I remember an experiment in which the similar poles of two magnets were pushed together and a coil was wrapped over them with a DC motor in series, connected to a DC source. I can't remember what happened next!
I remember a comment by Steven Marks about moving a magnet across thin wires.... ( Don't shoot me if I am wrong). Hubbard uses thin steel wires, so does Stan Meyer.
