Hubbard coil
Started by EMdevices, July 01, 2008, 05:03:36 PM
ramset
Quarktoo
Quote:
Me thinks the shorted coil trick of Thane Heins is a better way to go than Hubbard since Thane's work is simple enough that anyone can do it now, is proven to increase efficiency and is safe. Thane Heins has a good workable solution once you go beyond the pulse motor IMHO.
This is where some folks feel your off.
They think Thane is using substandard measuring techniques.
It would be VERY cool if you could come up with something that utilises Thane's Effect to perform work beyond any speculation,a decisive once and for all Test for OU.
That would be very cool.
Chet
Thanks Grandma
quarktoo
Quote from: ramset on January 09, 2011, 07:44:50 PM
Quarktoo
Chet
I could and would do that. Of course, I would want quid pro quo for buying hundreds of dollars of copper wire and a junk alternator.
I know a simple test. There was a couple of scientist from Brazil that made a Newman motor and used a scale 1 foot off axis and measured torque in foot pounds. That way everything going in (torque and RPM) and everything coming out (volts and amps) gets measured and the only thing not measured heat and friction losses are ignored since they always will be anyway. There is no way to ridicule the result.
It would not be ideal in terms of efficiency since I would be using an alternator that will not have enough coil winding space but should be close enough to compare the difference.
Odd how Thane has not evolved his research very rapidly. Watching his videos is like watching Groundhog Day in slow motion over and over...
quarktoo
There is one other possibility for this hubbard coil that nobody has thought of or pointed out so I will keep it to myself but it would require those two big black hoses to be coolant lines since it would get real hot and all that huge wire would actually be be copper tubing. Half of the tubing would have water in it.
ramset
Hubbard made 25000 watts
OUCH!!
You know he "played" on a MUCH smaller basis while he was learnlng .That would be safe to do ,we don't need to fry ourselves.
However,
I see you are seeking to collaborate on some serious experiments,or at least try some things ?
I hope you are succesful in getting "SERIOUS" people on board.
It would be nice to advance our understanding of these things!
Chet
Thanks Grandma
Paul-R
Quote from: ramset on January 10, 2011, 08:42:02 AM
OUCH!!
You know he "played" on a MUCH smaller basis while he was learnlng ...
Yes, but it is all about achieving resonance. Sometines, by altering the scale,
the problems of getting resonance increases.
