Magnetic OU principle, You should really take a look at this !
Started by Butch, July 02, 2008, 01:01:34 PM
Ergo
You are truly unbelievable and ingnorant in your stubbornness. Now I'm being rude, but you deserve it.
DIDN'T YOU GET THAT THE RECTANGULAR WASHER PILE ONLY HAVE HALF THE AREA OF THE NEOMAGNET?
THIS MEANS THE FLUX WILL SATURATE THE WASHERS AND THE EXCESS FLUX  IS FORCED TO TAKE ANOTHER ROUTE.
Sorry for shouting but this is probably the only way to make wizkycho understand, but I don't think he will get it anyway.
wizkycho
Quote from: Ergo on October 22, 2008, 03:58:44 PM
You are blind aren't you
look at the picture
http://www.overunity.com/index.php?topic=5064.msg133191#msg133191
washers together have bigger surface then magnets so they can not saturate Seeeeeeeeeee!!!!!!!!!!!!!!!!!!!!!!!!
You may shout but Space still works the same way, and says:
50:1 still very possible and you can't stop it ....maybe you can find something else. I dout it, but I dare you, and rise You 1000
Wiz
Blainiac
Aside from the current argument, has there been any other experimentation with purely mechanical or the coil setup?  As I understand, Yucca has been the only one that has started to build one.  I'm really interested in this promising setup...
I conform to non-conformism.
scotty1
I did some experiments....
I found that if you move the magnets closer than 2 mm to the iron, then the iron will change polarity.
In other words when the flux uses the iron as a path, then the iron is a different polarity than when the magnets are approaching the iron at say 10 mm distance.
If the N pole magnet approaches the iron, the iron end will be a S pole, but when the magnet is very close to the iron then the iron more or less becomes part of the magnet pole.
This is the base for the Wesley Gary motor.
I've tested it many times and the iron does indeed change polarity.
I used very fine iron laminations taken from a large electric furnace for my tests....I've got about 200kg of thin strips about 1 meter long....hahaha..I thought they might come in handy one day ;D
Scotty.
Ergo
Quote from: wizkycho on October 22, 2008, 04:19:15 PM
Then build the darn thing and learn I'm right in this matter.
Once built you might learn a thing or two and start seeing the whole picture instead of being so extremely narrow-minded.
So you are a poker player. This explains your complete lack of logic and beliefs in success without ever questioning your own ideas.
It's just like a poker game for you. Bet on success agains all odds and you might win. But you won't win against mother nature.
