Magnetic OU principle, You should really take a look at this !
Started by Butch, July 02, 2008, 01:01:34 PM
newton2
Hello Honoured Profiles
and
The Honoured Administrator
of This The Honourable OVER-UNITY-Forum  !!
Might I kindly briefly in a few sentences just mention about :
**********IF-WHEN a socalled SMOT/SMOTS-Actions-alike Device should be
attempted to become PATENTED and/or REGISTERED.......
THÉN there at least is this problematical Circumstance :
The PROPERTIES of the mu-r-permeabilities-materials
should be SO CLOSELY CORRECTLY DEFINED.......
and also MATHS plus PHYSICS-THEORIZINGS might "well"
indeed have to be INCORPORATED in such "Patents/Registerings"-Attempts...!!
And THÉN furthermore should be INCORPORATED
the "delicate-sensitive"   Adjustments-Procedures
plus "Tolerances for GO/NO-GO"
of such SMOTS like the INTERESTING INGENIOUS
WELL-THOUGHT Idea of this original Topic (page 1)//
this continued HOT-NEWS-going-on-Discussion  !!
***************as a mere Co-add :
The Honoured Administrator  Herr Hartmann more than ONE TIME
has kindly hinted about this Modification for Discussion also :
to have arranged an Electrical Currents Solenoides-Coil and
the "moveable" mu-r-permeabilities-pieces in SURDEN WAYS
of SetUps.............
Kindly frankly I "know" "some" about "how&why" in ways of
interacting a Solenoide with such mu-r-permeabilities-"pieces" ........
an interesting "combination" of both practical Appliances of
Physics/Maths-Theories and "Handy-Crafts"..........!!
MY KIND THANKS TO THE HONOURED ADMINISTRATOR  Herr Hartmann
FOR HIS KINDLY HINTING ABOUT A SOLENOIDE TOGETHER WITH
PIECES OF MU-R-PERMEABILITIES-MATERIALS........................
MIGHT I DARINGLY SUGGEST ,  THAT THE HONOURED  ADMINISTRATOR
DOES KNOW ABOUT THE POSSIBLE OU-ACTIONS  OF SUCH A SET-UP
OF  A SOLENOIDE  TOGETHER  WITH  MU-R-PERMEABILITIES-PIECES.........
OF COURSE THAT THE HONOURED ADMINISTRATOR HAS TO KEEP
IN DISCRETIONAL SECRETS ABOUT SUCH AN OU-Device of Solenoide + mu-r-pieces !!....
MIGHT I KINDLY MEAN ,
THAT HARDLY WILL PER  P.T.  THE HONOURED ADMINISTRATOR  STILL NOT UN-VEAL
ANY DETAILS ABOUT  THE WELL-FUNCTIONING   [ OU-Solenoides+mu-r-permeabilities-pieces ]
.......................might I just briefly mention a "little" of mere OU-RUNNING-Results of "my own" mere OU-Researches-
Results about such an OU-DEvice per [solenoide + mu-r-permeabilities-pieces ]  :
>> a TEN-PROCENT-"more-output" might be expected when-if using a "thick-Cu-wires"-multi-turns->>wound in
>> i.e. a 1:1-Lenght-to-diameter-"Air-Cores"-Solenoide and "using" HighFrequencies-properties-
>> ferrites-long-rods..........
>> BOTH a "Pushing-Force" might be "usable"......(to some "point" also "pulling"-Force).......
>> AND an IMPEDANCE-altering Circumstance might be "usable".......
>> THE TRAJECTORIES OF MECHANICAL MOVEMENTS OF THE Ferrites-Rods DO
>> are SIGNIFICANTLY IMPORTANT in MEANS of  xxxxxx.............!!
Might I kindly most briefly mention about the SMOT-alike-Method as mentioned
on P 1  in The Original Topic (my Thanks to the Honoured Profile having started the Discussion) and (my Thanks to THe Honoured Profiles + THe Honoured Administrator having so fruitfully kindly
ingeniously contributed per Their respective interesting Replies to Replies) :
ALSO A "PULLING" FORCE MIGHT BE USABLE.....(not just a "pushing"-Force-Action...)
THOUGH THEN PER ALTERING THE SET-UP OF MOVEABLE "SOFT-IRON-RODS/PIECES"....!!
WKR & have Yourselves a nice Day and Labouring Week and a pleasant Early Winter.....
and For Whom It is Relevant : Merry Xmas 2008  &  Happy newYear 2009 !
MY THANKS ABOUT YOUR ALL OF INTERESTING IMPORTANT CONTRIBUTIONS
TO
THE HONOURABLE  COURSE  OF  OU  !!
newton2
and
MIght I kindly briefly per a few sentences just hint about :
**********The "All" of Interactions between 2 separate nearby EachOther
Electrical Short-Solenoides in Means of
BOTH the mechanical-Works-Integral : S ( Fmag * dl )
AND   the Effects-Powers-Integral      : S ( Current(t) * Voltage(t) )..........!!
Allthough this Continued-going-on-Discussion per Replies to Replies
is mostly meant to be about SMOTS..........
THEN still "some" Realizings about Electrical Currents Coils
might also "do" in such  Discussions about SMOTS.......!!
And THANKS about the in the most former Reply
mentioned COMMERCIAL to Magnetical Materials /
Shieldings of Low Frequencies........
interesting in means of the Physics-Maths-Theoremes about
ElectroMagnetical Fields.......!!
Thanks about Your All of interesting important Discussions-Contributions to
The Honourable Idealistical significantly important  Course  of  OU  !!
WKR & have Yourselves a nice Day and a pleasant Early Winter
and For Whom It Relates : Merry Xmas 2008  &  Happy NewYear 2009  !!
molux
I all,
I can't wait the Demo Butch.... i'm so ecxited....
Thanks for your greate Job
Molux
molux
Hy Sirs,
(I can edit my previous message...)
I juste ask imself where come from this claim :"OU motors with a 50:1 output:input now possible !" (in red on top of the forum) ?
Molux
newton2
and
Might I kindly briefly just-a-little "Moneys-savingly" mention about :
*************DISCARDED "ELDER" Radio- & Computer-Electronics often
"have" i.e. most-lower-Frequencies-HF-suitable ferrites "Beads & Tubes".....
and "HF-ferrites-Aerial-Long-Rods"......
to might A-PART away from the Original Device for to use for
H-magnetical-fields-experiments.....................!!
And how about the fairly "strong" wall-notes-plates/refrigerators-front-plates
"gadgets-magnetes"............
and how about magnetes as A-PARTED away from small/medium-sized "standard"
DC-commutators-motors(generators) .................
YES, THÉN the really "strong" magnetes from "move-forth-back"-a-jumping-magnetes-rod
cased in a "clear-plastics"-cylinders-LAMP...
for to "drive" White-litting LEDS....
(though per a most too little accumulator-package)...............!!
THÈN the p.t.-times really "small-sized" commercially manufactured "Self-inductance" per
Coil wound on "little" open-fields-mu-r-ferrites-mini-rod..........
YES...........if-when "cheaply"-priced Components might do well in Experiments....also for OU....
thén o.k.......for surden COMMERCIALS DO MENTION RATHER" LARGE" NEW COMPONENTS PRICES OF SURDEN MAGNETES AND FERRITES MATERIALS , e.t.c. !
WKR & have Yourselves a nice Day and sooncoming Weekend and thanks about The nearly Past Season of Y 2008........
and have Yourselves a pleasant Winter´s Time and Seasonal Events.....!!
And For Whom It Relates :  Merry Xmas 2008 & Happy NewYear 2009 !
And my Thanks about Your All important significant interesting Contributions to
       The Honourable  Course  of  OU  !!
