Magnetic OU principle, You should really take a look at this !
Started by Butch, July 02, 2008, 01:01:34 PM
devrimogun
Quote from: Butch LaFonte on March 18, 2009, 06:10:25 PM
Listed below are links to videos that show testing of the 3 aspects that should allow the LaFonte Group, Ring Force Cancellation Perpendicular Magnetics Motor to operate in an overunity mode.
See video links >
http://www.youtube.com/watch?v=ngkEkeBL1Kk&feature=channel_page
http://www.youtube.com/watch?v=4Mlpr6o86X0
http://www.youtube.com/watch?v=OAxbOQ3nM8w&feature=channel_page
http://www.youtube.com/watch?v=btjit4WnH_c&feature=channel_page
http://www.youtube.com/watch?v=552L2-jG9P4
http://www.youtube.com/watch?v=sYdd8hu8YNA
http://www.youtube.com/watch?v=PwzKg1tiexs
Mr. LaFonte,
I know that in order to get recognition from the OU community you need to demonstrate OU beyond
doubt and that is (probably) why you are giving all your attention to a design that uses PM's which is
a no mans land as in all history noone was able to conquer. (I know some of the high ranked members
will jump on me for saying that and throw some names on me. My response is : Hey, what is running
in your cars guys?)
I read the thread from the beginning and I am stuck in the first movies you made
and refferred to on page 2 (I think). (Names are 1-10-99.avi, 1-7-08.avi etc.)
You animated some designs using coils.
If the forces you talk about exist (I think you mentioned 300 pounds using 7 blocks of 4X4X3''steel)
why don't you try to make a very efficient motor using coils first? (Even if its not OU or can't prove that its
OU)
Burning a few watts of electric sure beats burning gallons of gas.
Piece,
Devrim
devrimogun
Where is everyone?
Are you all busy replicating the Mylow (Newman) motor?
Blainiac
@devrimogun:
I have no idea, but I think I might have a solution for Yucca's design.  It is almost exactly like his, but there is a ring (or rings) of steel that completes the rest of the circle where the piston isn't.  This way, there is equal attraction between the angles where the ring is and where the piston part is, causing the magnet to glide by and easily skipping past.  The only thing I see wrong with this is that the added area of steel perpendicular to the magnets may cause Lenz law to be more present, keeping the gliding effect at a minimum...
Attached is a picture:
I conform to non-conformism.
derricka
I like the creative approach of this ring design. No doubt it will take very creative methods to tap into new sources of energy, as all the obvious means have been tried already. I have built some test rigs with separated rectangles of transformer lamination steel, similar to your piston.  I have found the rotational forces (through a magnetic field) vary considerably, depending on the degree of compression on the "piston".  You may have more luck with your ring design, especially if the ring also changes, to match the change in piston geometry.
