S1r PDF coil description and discussion !!!!
Started by xbox hacker, July 08, 2008, 03:20:41 PM
hydrocontrol
Quote from: xbox hacker on July 08, 2008, 05:15:25 PM
Refresh this page ...i updated my drawing, per his photo on the yahoo group!
Its also not to scale... ;D
That is a better diagram. Where does the 14 gauge uninsulated wire go ?? Looks like red wire insulation to me from the 'real device' photo. Having it feed from a lamp now makes sense as this would limit current flow. I bet the battery feeding this is taking a beating from back feed high voltage spikes. Looks like no diodes involved. Hummm.. Still not adding up..
bumfuzzled
Just built the coil and it did nothing other than give me the regular HV arc. I don't know electricity very well but I don't see what this is doing. You've got the HV inducing into the LV so how is this giving you 200 times more power??
cmichaelcouch
S1r:
I remember that you increased the carb jets 2 sizes in the El Camino 350 V8.  Did you do any increase of jets or whatever for the B & S 18 HP motor?  How did you increase the volume of water vs. gasoline in the B & S or did you?
Also, did you ever put a hole in the top of the water "tank" to allow the air in to displace the water draining out, to avoid the vacuum that would tend to make the water "pulse" out instead of flow evenly?
Capacitor 70
See the two comments above and please, comment as to whether or not you made these two adjustments to your motorcycle tests?
Michael Couch
ArrestCheneyBush
for 9/11 Treason (yahoo e-group)
Run your Car and house on Water (watercar e-group)
Public funding of elections, Defend the Constitution
Save 29,000 children today support UN MD Goals.
DELETE before you reply  to digests [Ctrl] [A], [Delete]
xbox hacker
Quote from: hydrocontrol on July 08, 2008, 07:15:40 PM
One end if the 14ga goes to the plug and the other goes to the ignition output. In the PDF he says to put a "limiter switch of some sort"... put a lamp inline with the output if the seconds winding and the ground.
xbox hacker
One thing that i would like to point out is the coil size compared to the nail size... here is a image to show you.
Also should the coil be wound a certain way? Or should that not matter ???
