S1r PDF coil description and discussion !!!!
Started by xbox hacker, July 08, 2008, 03:20:41 PM
russwr
I refer you to SEE AGAIN, the First 2 only, of the You tube videos of S1R9A9M9. The Briggs 18HP ran on water in carb for the back yard test, after several cars were converted in Georgia since 2005. My project was divided into 6 sections for duplication of Nathren's test. Now stage 5, I built 3 possible power supplies as having ISOLATED grounds. The final outcome of course, was water vapor pressure generated with minuscule amount of Hydrogen gas at late timing of 12HP Briggs engine. This was Nathren's and the 3 technicians invention that related to the successful auto conversions. Back at that time, unusual relays were used per cylinder that are not available. No parts list was issued because of that. The lawn mower engine had a substitute for the 400w Inverter box and set of relays, as a special hand wound triple wires magnetic coil. I assumed since the mower engine was also running, that a relay was also used, as it does fit into the plastic tub on side of the 18HP. There were no protections /safety items during that 2008 test. My circuit has 3 fuses, resistors, and diode bank of 10kv. Send me Email of your list of pertinent questions regarding those 2 videos , and I will explain. I spent very long time studying the web site, small notations, and videos to get it right. You could also look over my previous posts on water fuel sparks, as some of the answers are there.
russwr
The S1R9A9M9 triple coils assembly had several purposes same time. The magnetic field of 10A peak, 5A average DC causes the required time extension of spark so as water has more contact with it. It was not a step up or step-down transformer. The ignition coil on Briggs mower is called a Magnetron as it has an embedded SS trigger switch. Mowers are negative spark with positive ground. That means the spark jumps upward from metal casting to center of plug. An autotransformer with 3 leads requires a ground wire for primary. The spark would never work, as it would bypass plug and go up the side wire. That means S1r coils is just a type of electromagnet only, with end wire hooked to the negative high volts at top of plug. No adjustment of Briggs timing. Therefore, since old car engine could have distributor turned for timing change, Nathren used coils for that purpose. The cars conversions had inductance about 1.5MHenry for high volts line that also contributed to extended timing. So as the Briggs 18HP had RELAY in the plastic tub on side of engine as it dimension-ally fits. The same amps for magnetic field over plug wire also goes THROUGH spark plug. Electrolysis at plug tip electrodes for small Hydrogen is supplemented with water vapor pressure to move piston. The inductors provide also a required magnetic field at plug tips. The cars conversion has 400W 110vAC inverter box and output diode 50% duty cycle on time, while the Briggs alternators AC output to DC with diode or bridge rectification are outputting Pulsing on + off DC power at 50% duty cycle or full wave Bridge DC which has more power. The Briggs engine DUAL ALTERNATORS at low cranking speed has no output. The 12v battery ran circuit until engine was at idle RPM so as alternator would run circuit. Then battery was removed. It has 5-14.5 A capability at idle. The ohms resistance of circuit was in series as about .7-ohm MH coil, and voltage drops of the diodes for the formula I = E / R reduces the 12v battery.  His car and mower engine conversions had 2-3 spark gaps in series. This kept the plugs firing, as not fouled with water. Do you understand all this?? The Champion plug comes apart so as resistor can be removed for zero ohms so as current can pass through spark plug. *****And there is a reason for the S1R coils having bare copper wire for the high volts cable section that bothered many other people over time. It has to do with GETTING cross - leakage inductance, so as there is a higher LOW volts to push the amps to plug, since plug was Champion YC12Yc 125 ohms, not zero ohms. They did not know it could come apart. The superimposed high volts over the 12v DC line allowed the higher push to get through the 125 ohms. Back to Ohms law E = I times R. Is the YouTube S1R9A9M9 Briggs water engine videos making more sense now?? The tech web site is shut down. The S1R coils copper insulated wiring came from chassis #16 gauge wiring of a riding lawn mower. Nathren's son used oscilloscope to get current reading peak of spark plug amps. Average current is about ½  peak amps as on a common hand meter. Put that in your pipe and smoke it.  Questions?
TommeyReed
Hi russwr,
I would like to do experiments on your system, can we work together?
Tom
russwr
Today I tried to replicate small test as described in the tech literature of S1R9A9M9 from 2008. The web forum had page regarding a side leakage inductance of wire coil wrappings that would reduce current flow on meter in 60 turns, by inducing a reactance ohms in the low voltage line, from the high voltage line. (increasing ohms) I varied the insulated high volts wire to bare copper wire. I varied the end connections for polarity of the outer coil as matching turns direction. I used a steel bolt core inside plastic tube with the 2 types ignition wire and then the 60 turns insulated wire from car battery. I had added 7kv diodes in series to protect the battery from the 6kv ignition. When repeatedly pushing the ignition single firing button switch, the amp gauge value never changed with all different adjustments. I don't doubt there was a higher volts transfer from one side to the other, since other people who did the test, had held the 2 wires wires and got shocked before.This was assuming the triple coils assembly of 2008, on the mower engine running on water in carburetor, Nathren needed the higher volts due to the spark plug being 125 ohms and can't get 10 amps to go through with just car battery. The superimposed volts over 1000 would push the 10 amps through the spark plug. Because of these negative tests I did, , it is now still possible of the bare ignition wire used to insure proper spark plug firing with the added 10 amps current. They may not of known in 2008 that Champion plugs can have the resistor removed and replaced with copper segment. The larger Briggs engines require LONG REACH Threads type plugs while smaller ones are short reach and have readily available zero ohms spark plugs. He probably , back then, could only get Champion QC12YC as long reach 125ohm instead of 4000ohms regular plug. My current series circuit can have the same resistance values without having to change them to get unchanging 6 amps. All his previous car engines had ran on 6-7 amps. In the original message board article from 2008, 20 amps on meter was reduced to 12 amps to same resistance load when cross firing was done for an experiment The only difference was, I used separate resistor for load to ground, as was done in the original 60turns test, rather than firing the amps through spark plug- AS WAS DONE IN THE S1R9A9M9 2008 You tube videos of running self powered engine of Hydrogen gas and water vapor pressure. My query at this time is whether to use half wave DC or Full wave DC. Both earlier conversions, cars + Briggs 18HP,  had used half wave dc , as there is an off time 50% duty cycle, to make usage of the Back EMF from inductor inside relay greater than 100v.There are voltage drops in series from my beginning 38V DC so as about 20v is left for the spark plug. The 2008 videos had car battery 12v for starting, battery removed, then switched to alternator DC about 12-18v DC. He neglected to say it was self running . Most likely since all earlier car conversions had used certain dual coil relay sealed in vacuum per cylinder, that one was also used with the Brigg 18HP mower engine because it also fits inside the plastic deli tub on side of engine, and INDUCTORS ARE REQUIRED also . See videos again. The AI computer answered my question recently and gave a worked formula to get a back EMF of 100v from inductor with parallel diode to circuit output using 1.5MH inductor coil, 20volts, and 6 amps at fast discharge of 11 milliseconds. Inductor is also in High voltage line. This is ALSO as circuit published that was used in the car engine conversions based on speed of only INDUCTIVE TYPE ignition firing of spark plug. (The tiny electrodes of plugs may require much higher volts for common electrolysis  to get sufficient Hydrogen WITH the accompanied vapor pressure to push pistons.)
russwr
 It was called "The 60 Turns Coil Test". I suspect now, that the analog with needle panel current meter would not register the fast ignition impulse as impressed on the adjacent wires. A small, open board type, China $35 battery operated with optional AC supply oscilloscope from E bay DSO 138 as "welded/ completed " ready to use, should be used with one ohm resistor on the GROUND side of the current line returning back to the power source. Ohms law says the volts read over resistor is the actual pulse current since I = E/ 1. The Georgia 3 technicians back about 2008 did have an old oscilloscope for use.The ignition pulse returns through engine casting for ground  and not interfering on the ground side back to the 2nd power source. There would be interference and possible damage,  if scope resistance probe was used on the same side as the high voltage .
