Infinity Coil
Started by z.monkey, July 11, 2008, 08:12:41 PM
z.monkey
Howdy Y'all,
This thread is going to document the construction of the Infinity Coil.  This device is based on the Hubbard Coil, a free energy device which was build by Alfred M. Hubbard in the early part of the 20th century (1919).  There is a legend of this device which powered a boat around Portage Bay, Washington for several hours, with an annotation that the device would periodically levitate.  In the Hubbard Coil thread EMDevices is attempting to replicate the Hubbard Coil using Cook coils.  GiantKiller has has some initial success with his four air coil setup.  My take on this design is eight solenoids connected in series in a loop.  The operational theory is that when an initializing, temporary DC pulse is applied to this device can operate for an extended period of time, perhaps even perpetually.  Additionally, I am speculating that additional energy can be extracted from the device without altering the initial charge and operation of the device.  Theoretically the device can supply a great amount of power, far beyond its initial charge.
The operational theory is that there is a charge that is cycled between the inductors in a loop.  Current leads the voltage in an inductor by 90 degrees.  This phase delay is the method in which this device works.  An inductor is charged, developing a magnetic flux field.  As the charging current is stopped, the inductors magnetic field will collapse, generating a current flow out of the coil.  The current flows around the loop into the adjacent inductors and develop magnetic flux fields within them.  This continues around the loop infinitely.  Theoretically there should be a loss of charge as the current encounters the resistance of the wire in the inductors.  However the unique nature of a set of coils in this configuration seems to be drawing extra energy from an unknown source.  I can speculate that this energy is coming from subspace, the Etheric Plane, or another dimension in spacetime.  Truth is I don't know firmly where it is coming from.  This is what we are going to figure out here in this thread.  I do not know for sure if "free" energy is a physical matter phenomena, or if it something from a alternate plane or dimension.
Initial construction plans call for the construction of eight primary coils which have one inch diameter iron rod cores.  The secondary is a single two inch diameter iron rod core.  Both the primary and secondary cores will be wound with 22 gauge stranded wire with heavy insulation.  The charge initiator will be a 12 Volt SLAB (Sealed Lead Acid Battery) and a momentary switch.  The central output coil will have terminals to connect various loads.  I am going to keep this project as simple as possible. Eventually there will be a feedback circuit to recharge the SLAB.
Based on GiantKiller's preliminary success the Infinity Coil is looking very promising.
Here's to our success...
Blessed Be Brothers...
Goodwill to All, for All is One!
ramset
Z SO ITS A BUILD  do you need /want replicaters ? Chet
Thanks Grandma
z.monkey
Howdy Ramset,
Absolutely!  I will post all construction details on this thread.
Here is the preliminary schematic...
ramset
Z SWEET thanks will follow and replicate as you post info   Chet PS I like how this coil came to the world!!
Thanks Grandma
z.monkey
Howdy Y'all,
The coffee is kicking in and I noticed that there are a few details I left out of the initial post.
The name of the coil is representative of the way it works.  Look at the diagram in the first post.  The annotations on the coils are the voltage phase in degrees.  On the top side the phases represent a sine wave.  On the bottom side the phases represent an arcsine wave.  If you represent both a sine wave and an arcsine wave in the same space you get an infinity symbol.  This is more than a name and a symbol, it represents the way the device works.  By having eight primary cores electrically you create an infinity wave structure in the device.  This is the operational philosophy where the initial charge initiates the wave structure, and the nature of the device allows the wave to continue traveling within the device.  The secondary output coil is inductively coupled and is usurping power from the oscillating primaries.  The eight primary cores surround the secondary, aligned longitudinally, and spaced at 45 degree increments around the diameter of the secondary.   The secondary is inductively coupled so the primary cores need to be in close proximity to the secondary.
I have noticed that there is a lot of bad information out there concerning the Hubbard Coil  Whether this is lack of understanding on the writers part, disinformation, or misinformation I don't know.  I have been researching the Hubbard coil for close to 20 years.  I have built many of the interpretations that I have read about.  While this is extremely frustrating it did teach me what not to do.  And what I have learned I am putting into the Infinity Coil.  I have seen many way overcomplicated interpretations.  I have seen on analysis recently which beat the coil to death with math.  Bottom line is keep it simple.  Real power in nature is NEVER complicated.  It may be complex in understanding, but the fundamental mechanism is simple in nature.  Same with the Infinity Coil.  We are only using one kind of wire on all the windings.  The cores are all uniform and fabricated out of the same materials.  The circuit surrounding the coil with as simple as possible and not use semiconductors if possible.  If we do use semiconductor they will be the most simple, and rugged available.  Perhaps the most important thing is the cost.  I plan to ferret out the most cost effective, and commonly available materials to fabricate the device.
Remember, keep it simple, and cost effective.
Lightning in a bottle.
