Infinity Coil
Started by z.monkey, July 11, 2008, 08:12:41 PM
z.monkey
Howdy Y'all,
Ramset, the these type transformers use inductive self resonance to oscillate.  They generate a strange magnetic flux pattern that forms a vortex in the center coil.  This vortex accelerates the the flow of magnetic flux through the device which generates the power gain.  I suspect that Soft Particles are the source of energy that we are seeing here.  The magnetic flux vortex is drawing Soft Particles in to the device where they disintegrate and manifest as the extra energy.  These type devices do not need radiating elements to generate energy.  Using a radioactive substance in them would poison everything around the device.
Pese, Thanks for that plethora of information.  That is by far the biggest Hubbard collection I have ever seen.  What do you think of the Infinity Wave Theory?
More on Soft Particles here...
http://www.overunity.com/index.php/topic,4255.0.html
More schematics coming.  Going to the hardware store today to pick up the core materials.  Then I'll have to spend a few days machining the materials.  In the spirit of conservation of effort I am going to use the same core design as on the Soft Particle Reactor.  The primary cores will be a 1/2 inch inside diameter by 8 inch long iron plumbing pipe.  A 1/2 inch by 10 inch long machine screw fills the space inside the pipe and provides more core material, as well as hold the coil together.  The secondary will be constructed from a 1 inch inside diameter iron plumbing pipe and filled with 1/8 inch diameter iron rods.  I'll build 2 end plates out of some sort of hardwood, I used poplar before.  The end plates hold the ends of the bolts, so we can drill an array of 1/2" holes to hold the primary coils in the proper orientation.  The secondary coil will be held in place by the primary coils.  I am working on the mechanical drawings.  I downloaded FastCAD 7.1 to make good electronic copies.
Blessed Be Brothers...
Goodwill to All, for All is One!
ramset
z couple questions  can grade 2  1/2 inch threaded rod be used  or plain rod ? they make 1/2 inch flat head internally threaded posts  for the ends   also 1/8 bald rod for the inside? I want to use identical components  Iron psi and metals/properties  also is ABS or Plexi OK just some ideas to standardize the build  This is your show will go with whatever you decide    Chet
Thanks Grandma
z.monkey
Howdy Ramset,
The reason I am using machine screws is to hold the coils together.  You can use rods if you like.  You will have to find another way to keep the coils together.  The hardware grade should be as low as possible.  The softer the material is the better it will work in this application.  This is why I chose iron plumbing pipes for the main part of the core.  They are not designed to be structure, rather they are designed to seal well, hence soft iron.  The 1/2 inch bolts are the most common you would find at the hardware store.  Low grade, cheap price, good for flux conduction.  The primary core internal rods are also from the hardware store, in the iron stock section.  Most hardware stores have a variety of rod and tube stock.  If you can get iron rods that would be best, but low grade carbon steel will work too.  Plastic or Plexiglas are acceptable for the end plates.  I like using hardwood because I do carpentry and I generally have some nice wood scraps hanging around.  You'll notice in my other posts every project I do has wood in it.  This coil should scale well.  I have been thinking of doing a miniature one for portable stuff, and a giant one to run my air conditioning compressor...
ramset
Z Thanks for the info   most hardware[cheap stuff] is to grade 2 specs no problem    wood only gives me concern in its ability to retain moisture  maybe some conductivity?  I can research softer rod if you feel it could help [im VERY well connected with these manufacturers]  Chet PS nice attic job
Thanks Grandma
armagdn03
Quote from: z.monkey on July 11, 2008, 08:12:41 PM
Howdy Y'all,
This thread is going to document the construction of the Infinity Coil.  This device is based on the Hubbard Coil, a free energy device which was build by Alfred M. Hubbard in the early part of the 20th century (1919).  There is a legend of this device which powered a boat around Portage Bay, Washington for several hours, with an annotation that the device would periodically levitate.  In the Hubbard Coil thread EMDevices is attempting to replicate the Hubbard Coil using Cook coils.  GiantKiller has has some initial success with his four air coil setup.  My take on this design is eight solenoids connected in series in a loop.  The operational theory is that when an initializing, temporary DC pulse is applied to this device can operate for an extended period of time, perhaps even perpetually.  Additionally, I am speculating that additional energy can be extracted from the device without altering the initial charge and operation of the device.  Theoretically the device can supply a great amount of power, far beyond its initial charge.
The operational theory is that there is a charge that is cycled between the inductors in a loop.  Current leads the voltage in an inductor by 90 degrees.  This phase delay is the method in which this device works.  An inductor is charged, developing a magnetic flux field.  As the charging current is stopped, the inductors magnetic field will collapse, generating a current flow out of the coil.  The current flows around the loop into the adjacent inductors and develop magnetic flux fields within them.  This continues around the loop infinitely.  Theoretically there should be a loss of charge as the current encounters the resistance of the wire in the inductors.  However the unique nature of a set of coils in this configuration seems to be drawing extra energy from an unknown source.  I can speculate that this energy is coming from subspace, the Etheric Plane, or another dimension in spacetime.  Truth is I don't know firmly where it is coming from.  This is what we are going to figure out here in this thread.  I do not know for sure if "free" energy is a physical matter phenomena, or if it something from a alternate plane or dimension.
Initial construction plans call for the construction of eight primary coils which have one inch diameter iron rod cores.  The secondary is a single two inch diameter iron rod core.  Both the primary and secondary cores will be wound with 22 gauge stranded wire with heavy insulation.  The charge initiator will be a 12 Volt SLAB (Sealed Lead Acid Battery) and a momentary switch.  The central output coil will have terminals to connect various loads.  I am going to keep this project as simple as possible. Eventually there will be a feedback circuit to recharge the SLAB.
Based on GiantKiller's preliminary success the Infinity Coil is looking very promising.
Here's to our success...
Im writing this to save you alot of time that could be better spent.
In your diagram, you will notice that there is one coil between input leads, and many more circling around, the charge will be distributed between all coils simultaneously with an AC signal, with most (80 percent or so) going through the path of least resistance, this being the coil centering the AC input. Upon collapse the charge will have nowhere to go, so if the freq is fast enough, it will be absorbed into the parasitic capacitance of the coil, and recycled for oscillation with the inductance, as all circuits with capacitance and inductance do under the correct conditions, (an effect which could be taken advantage of, but not in line with the workings of this device according to your description) or it will collapse, and the momentum of it will cary on into the negative cycle of the AC current being fed into it. With this setup, 80 percent of the energetic effects will be taking place in one coil alone, and it will not work in a circular pattern. All coils will charge, and all will discharge at the same time. Along with this flaw, you have not taken into account resonance between any of the components.
not that you cant build this device and get it to work, just rethink your game plan.
Good luck!
I wish I could turn my brain off sometimes, then I could get some sleep.
