Infinity Coil
Started by z.monkey, July 11, 2008, 08:12:41 PM
z.monkey
Cores after machining...
Goodwill to All, for All is One!
z.monkey
Central core rods, I didn't buy enough, so back to the hardware store I go...
z.monkey
Lots of cores, lots of work...
z.monkey
Infinity Coil Core!
Got Core?
Blessed Be Brothers...
z.monkey
Howdy Y'all,
Here is an updated schematic of the initial build of the Infinity Coil.
I made some changes yesterday I forgot to mention.  I changed the size of the center core.  I had specified a 1 inch inside diameter iron pipe.  Well, its outside diameter was a little small, 1.325 inches.  We want the center core to be twice the diameter of the primary cores.  So I increased the center core to be a 1.25 inch inside diameter iron pipe whose outside diameter is 1.67 inches.  The primary cores are 0.850 inches, so that is closer to double the diameter.  This changes the Bill of Materials a little because I will need more 0.125 inch iron rods to fill the center core.
Changes in the schematic are I took out the steering diode and the cap that was in parallel with the coil.  I also removed the feedback circuit, we can mess with that later after the circuit is working.  I also changed the way the battery is applied to the primary coils, it is now hooked up 180 degrees out of phase.  I think this is the best way to initialize the device.  The schematic now only shows what is absolutely necessary for operation in the very most simple form.  I figure we want to start from the bottom, it can get more complex later as we need features.  I plan on winding secondary winding under the primary drive coils but not using them at this time.  Theoretically we can draw energy off any of the cores.  The schematic only shows the primary coils.  The Infinity wave travels in the primary coils on the primary cores.  The output coil on the center core is the power coming out of the very most simple version.  However with secondary coils under the primary coils, we can draw power off any of the cores, in two sets of all four phases, and the central output core.  So altogether we could potentially have 10 output coils on the device as it is.
