Infinity Coil
Started by z.monkey, July 11, 2008, 08:12:41 PM
Sweet project you got there mate. Keep it going  ;).
z.monkey
Starting the center core.  This core is twice the diameter of the primary cores.  It takes a lot longer to wind this one, even thought it is the same length.  There are around 480 windings on the center core secondary winding and 100 windings on the center core primary winding.  Both the coils on the center core are center tapped and connected together at the center tap.  The plan is to use the center tap here to connect the center of the output coil to ground.  It is not necessary, I think this device will work OK when floating, but for a permanent installation it would be best to have the device grounded to provide a frame of reference voltage.  The ground on the center tap can also provide a supply of electrons for the output coils...
Goodwill to All, for All is One!
z.monkey
Here is the secondary coil for the center core with center tap...
hartiberlin
Very nive build , z.monkey !
Have set you up as Elite member.
Keep on going !
Many thanks.
Regards, Stefan.
z.monkey
Howdy Y'all,
Thanks Broli and Stefan, I appreciate it!
Here are some more pictures.  The center core is finally fabricated and in its new home...
Blessed Be Brothers...
