Infinity Coil
Started by z.monkey, July 11, 2008, 08:12:41 PM
z.monkey
Howdy Drannom,
I reviewed the theory of Superlight.  It is very similar to a couple of other bodies of work that I have come across.  One is Einstein's Unified Field Theory, the other is Cater's Soft Particle Physics.  The idea that one underlying source of energy is manifesting itself as all other forms of energy is not new to me.  The theory of Superlight is all encompassing.  From what I understand light, gravity, magnetism, life energy all have their source in Superlight.  Or put another way, Superlight affecting different materials creates these seemingly different phenomena, but in reality it is all Superlight being refracted off different materials, causing different side effects.  Some of these materials integrate the Superlight, such as life forms, and the Superlight becomes an integral part of their being.  This is a very interesting theory.  I am surprised that I have not come across it before.
Perhaps the Infinity Coil is like a macro sized crystal capable of stepping down the Superlight energies to electricity.  Or maybe the Infinity Coil is like a synthetic crystal due to its construction.  The idea being that we want to slow down the super high frequency energies and redirect their path into the coils of the device.  Using a very heavy, high permeability core would generate large friction for the superlight photons.  As they slow down they combine into a flow of hard electrons, hence the electric output of the device.
The crux of the matter is that we do not know why the Hubbard Coil works.  There are legends and stories, but no data sheets, no physics, no teachers to ask.  This thread is a crucible in which we are going to burn away bad theories, erroneous stories, and inaccurate legends until we are left with the truth of why the Hubbard Coil works for all time.  The Superlight theory is very close to the Soft Particle Physics theory which I am holding accountable for the reason why the Hubbard Coil works.  The Infinity Coil is my recreation of the Hubbard Coil in every conceivable historical detail.  If I find there is a better build, I will rip apart the coil that I have made and build another one.  I have already done this once.  The Soft Particle Reactor was my last attempt at the Hubbard Coil.  I had found through further study that my design was wrong.  So I ripped apart the Soft Particle Reactor and rebuilt it as the Infinity Coil.
BTW, the build is nearly compete.  I have the coil wired.  I have added the control switches and the output terminal block on a little deck under the coil.  I am adding a lid and a handle tonight, then we start testing.  I did hookup my scope last night and connect the infinity loop.  Just sitting there on my bench, unstarted, it was generating a 2 Volt sinewave at 400 Hertz.  So without adding any energy to the system it is generating a 2 Volt sinewave at 400 Hertz, hmmmm....
Superlight travels at Warp 2 (SoL2)
Blessed Be Brothers...
Goodwill to All, for All is One!
guruji
Hi Z monkey all that much work for just 2v it's not worthed to build.
Anyway thanks for trying and showing to others.
z.monkey
Howdy Guruji,
That is 2 Volts out on NOTHING in.  I believe that equates to Overunity...
starcruiser
He's gotta kick start yet.
Regards,
Carl
Quote from: guruji on July 23, 2008, 03:03:55 PM
Hi guruji all that much English classes for just skipping text it's not worthed to learn.
Anyway thanks for trying and showing others how foolish you are.
