NEW GUY HERE!
Started by h2ex0rz, July 14, 2008, 12:00:54 AM
hunter
I received mine recently from this guys.
http://www.aquapulser.com/product.html
Haven't installed it yet, because I'm looking for a cheap oscilloscope for it, but looks well build unit.
This guy also has PWM's and he do customs too.
http://www.pwmpower.com/
Later I will buy one from him too (I like his 30amp. model). It costly items, but if you want results you need to invest.
Hope this links helpful to you.
h2ex0rz
Hey guys thanks for the info! Electricme, I actually got ahold of a PDF that has ALL of Stan meyers work! Its pretty crazy to read about how he made his invention work, and I still cant comprehend how it works!
and BTW, thanks for your input as well on ignition timing for a small engine!
hunter, the aquapulser site seems to carry a better PWM that will go up to 500khz. Thats pretty nice. Although, I have heard/read somewhere that Stan Meyers had his frequency in the Mhz range? Although thanks for providing a site where I can get my grubby little hands on one! :)
SO, I have a couple other questions!
1. I've been arguing with some people lately on some other forums, and they are telling me that you cannot run an engine on Hydrogen alone? WHAT? What is this all about? I've already seen 2 cars on video do so, but not with an HHO generator.. But still, its hydrogen! They seem to stand proud that they can sey they know the laws of science and it cannot be done? .....lol, maybe I'm just the ignorant one here?
2. Is AC or DC voltage better for HHO production?
Yucca
Hi h2ex0rz,
If you want to test/calibrate your PWM circuit then you can get free oscilloscope software that uses your soundcard input for sampling, it should take you up to 24kHz. Here's a free one I found after a little search:
http://www.dirfile.com/freeware/oscilloscope.htm
I haven't downloaded it and tried it because I have a scope already, good luck with your HHO stuff.
stickittooil
Hey  there,
  I am a newbee as well, I have built and am using a very simple Water 4 Gas electrolyzer in my truck rite now. I have done alot of research just like you and now I am ready to move forward because that little cell creates nothing compared to some of the designs I've seen online. My next step is...and I am in the process of getting all my supplies together to build a plate cell, and putting together a PWM to drive it.
  As far as the PWM I found what appears to be a great Youtube vid by a gentleman who calls himself "ZeroFossilFuel" he is just loaded with some good info and he has a vid on there on building a load sensing PWM that I think even a person like me who isn't an electronics wizard by any means could build.
  Here is the link for the PWM vid this is #1 of a series so you will have to get the rest of them by going to his channel and pulling them up. I recommend you browse his clips he has many projects on there and bounces around a little so the vids for one topic may not immediatly follow the one you just watched.
http://www.youtube.com/watch?v=bjxKsCdpr0Y
Later,
S
stickittooil
Quote from: h2ex0rz on July 16, 2008, 01:29:05 PM
Hey fellow new guy,
  On the question of using hydrogen alone it doesn't burn...it explodes and most ICEs can't handle the abuse this stuff creates alone. I don't know where I saw it but somewhere a guy posted a photo of a piston out of his car he tried to run on pure HHO and it cut a hole down the side of the piston that looked like someone took a cutting torch to it. It cut not only the piston but also cut through the rings which are much harder metal then the aluminium piston.
HHO's octane level is way to high for todays ICEs, while reading IronHead's thread "High voltage HHO" the discussion came up about finding a mix of HHO and some form of inert gas to tone it down sounds to me like an avenue to research and test.
  On AC or DC I have no idea...I hope someone can answer this one for both of us. In my opinion it should not matter but you would be talking about a different type of regulating of flow and probably massive plates and alot of electrolyte. I'm just guessing I really haven't even gotten close to the point where I could consider the possibility of trying it...a long way off.
Later,
S
