this pyramid should produce electricity. (thomas trawoger's pyramid explaned.)
Started by nitinnun, July 16, 2008, 04:57:47 AM
nitinnun
by the way. make the gap between the copper and aluminum as small as possible.
the wider that gap, the more magnet energy will escape through it, back to the peak.
the only reason why i drew the black gap that thick in my drawing, was to make the concept clear.
that the copper and aluminum must never touch electrically.
therealrasta
So.. Do you want the pyramid to be hollow or solid?...  Would a solid aluminum base and maybe a piece of plastic and then a solid copper top be ideal?
nitinnun
energy hits the peak/sides of the pyramid, then bounce downwards.
some energy moves up into the air above the peak/sides.
but most of the energy moves downwards, to the base.
this is EXACTLY what a diode does. the energy flows better in one direction, than in the other direction.
the shape of the pyramid is what causes this current/diode effect. so if the insides were solid metal, then only the maximum magnetic capacity, would increase.
the amperage/current, would likely be the same, as a hollow pyramid.
build whatever is easiest/cheapest for you to build.
if it produces enough electricity to run a computer fan, then it will impress countless people.
you will become their hero. and i will be forgotten......
just don't attach your name and face to your pyramid, like thomas trawoger did to his.
or else you might disappear one day...
nitinnun
....i thought over my above post, and realized the following:
the pyramid captures/stores ANY energy, which enters it!
the energy enters the peak/sides, hits the peak/sides, bounces downwards, moves out the base, then swings around and back into the peak/sides.
then the energy does this again, until it eventually gets eaten up by the resistance of whatever material the pyramid is made of.
because of this, a pyramid with an empty "floor", would have more amperage/current than a pyramid with a solid floor.
......the pyramids in egypt had "wells", in the center of their bases,
these wells must have concentrated the amperage. so that when the amperage shot further out further downwards. then swung back up to the peak, in a MUCH wider swing.
this wider swing must have captured more energy for the pyramid.
because of this well and the wider swing, the pyramid collected energy, as if it were far larger than it was! because the wider swing of the magnetic field, brought more energy back with it.
anyway the pyramid is not a power source. it is a collector of whatever energy enters it.
pese
